Old 04-08-2008, 12:32 AM   #1
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
Default Diff temp light comes on once in awhile??
This just started to happen It even does it when the cars cold sometimes. It seems like it started doing ti when I got the Hydra back from updates. Could the Hydra be doing this? I was thinking maybe the sensor was going bad. It's so weird.
boostedrex05 is offline   Reply With Quote
Old 04-08-2008, 09:18 AM   #2
Default Re: Diff temp light comes on once in awhile??
Bump for some help.
Old 04-08-2008, 01:59 PM   #3
Fav Mod: Motor Mounts
So it turns on when the car is just sitting there warming up?
Old 04-09-2008, 09:32 AM   #4
no just when I'm driving. except for one time when i put the Hydra in after I got it back from the 2.17R6 update then it was on when i first started it up for like 3 minutes and went out.
Old 04-09-2008, 04:38 PM   #5
By the way I only use subaru LSD diff fluid in the rear and Subaru Extra S in the tranny.
Old 04-09-2008, 05:55 PM   #6
Fav Mod: Ricer Flyby
is it possible that the sensor is loose?
Old 04-09-2008, 06:46 PM   #7
One of two things...either the sensor is wrong or your rear diff is blown.
Old 04-10-2008, 09:28 AM   #8
Well lest time I changed the fluid witch was a month ago the fluid was good I've never seen any metal in the fluid don't have any sign's of a blown diff.
Sensor can't be wrong because it's all stock. So It's ether a bad connection witch is what I got my money on because it seems to fade on and off sometimes. or a bad sensor.
Old 04-10-2008, 09:29 AM   #9
could have came loss last time I changed it gonna check that.
Old 04-11-2008, 09:12 AM   #10
Fav Mod: so far? RCE T2s
or the diff fluid is low or old. my light came on when I went around off ramps hard till I replace the fluids.
Old 04-11-2008, 06:52 PM   #11
Fav Mod: nothing significant yet
Anybody Know what the Part Number is of that Sensor I know it's listed as a Thermal Switch?
Grog The Red is offline   Reply With Quote
Old 04-11-2008, 09:52 PM   #12
If the diff fluid is low why would the temp light come on? I noticed if I hit boost it goes off. It was flicking for a little today when i pulled out of my drive way but when the fluids get warm it doesn't come on at all.
Old 04-18-2008, 09:43 PM   #13
I un plugged it then plugged it back in now it's fine soo weird.
Old 04-20-2008, 08:34 AM   #14
Car: 06 STi #86 STU
Diff fluid low = inadequate lubrication which leads to increased heat. Assuming the sensor is functioning properly I would say this is a real possibility. However, given your description I would have to lean towards the electrical gremlin side, either loose connection somewhere (lots of fun to find) or a failing sensor in the rear end.
Rosco46 is offline   Reply With Quote
Old 04-20-2008, 10:06 AM   #15
yea the problem seem's to be solved I puller the fill plug and the fluid streams out so I know it's full. Again my problem was when it was cold.
