Old 03-29-2008, 02:25 PM   #1
Default trans fluid change help
ok so jiffy lubed striped my drain plug bolt on the oil pan plug. My question is can i just take out the oil pan little bolts and leave the 14mm bolt in? what options do i have? my car is on jacks right now
normansti is offline   Reply With Quote
Old 03-29-2008, 02:41 PM   #2
Default Re: trans fluid change bolt stripped help
bumpe
Old 03-29-2008, 04:19 PM   #3
helpe
Old 03-29-2008, 04:48 PM   #4
Car: White:05STi/04RSX-S
Default Re: trans fluid change help
did they strip the bolt while tightening the bolt or did they strip the bolt trying to take it off?
if the outside of the bolt is stripped then your gonna have to use a tap and die on the bolt head or something.... you cant drain the oil from unbolting the oil pan, it will be too much mess... you can start by removing the filter...
Es Tee Aye is offline   Reply With Quote
Old 03-29-2008, 04:59 PM   #5
Send a message via AIM to rev_happy_sti
why not just buy another one of those little pans on the bottom of the tranny and change it next time you change the fluid?
rev_happy_sti is offline   Reply With Quote
Old 03-29-2008, 05:31 PM   #6
Car: 05 STi WR Blue
Stripped/destroyed Tranny Drain plug
you should check this thread out.
Swenke is offline   Reply With Quote
Old 03-29-2008, 05:36 PM   #7
the guy at jiffy lube was supposed the be draining my oil when he tells me that he cant get the bolt off so I look to see what bolt he is on and its the transmission bolt. I found out today while under the car to change my trans fluid but I couldnt do it cuz i couldnt get the bolt off. I dont care if I make a mess, can i take the little oil pan out to change the fluid?
Old 03-29-2008, 05:40 PM   #8
Nice find. thanks ill just drop the oil pan tomarrow morning and try not to make a mess.
Old 03-29-2008, 05:54 PM   #9
Fav Mod: Synapse FMIC
Assuming yours looks like the drainplug in that link, you could 1) buy a new drain plug and use a bolt extractor to remove the old drain plug or 2) use a dremel on it and make two wide flat surfaces, then use a big crescent wrench to remove the plug.
jays05 is online now   Reply With Quote
Old 03-30-2008, 04:33 AM   #10
I like those ideas. Thanks
Old 03-30-2008, 10:42 AM   #11
ok so I did drained it and cleaned off the magnet and there were a few metal shavings, glad I did it this way. The only thing that puzzles me is I let it drain for about and hour and I put 3.5 quarts in and warmed up the car and the checked it and its to almost full. I thought it takes more then 3.5quarts.
Old 03-30-2008, 08:08 PM   #12
Banned
Car: White and Nerdy
Fav Mod: PayPal !!!
jesus are we talking about the oil pan drain plug or the tranny drain plug ? you said both in the thread .................................................. ...............................................
Nasioc_STi is offline   Reply With Quote
