Old 03-23-2008, 08:04 PM   #1
Default Stock Drivetrain Limits
I was looking around and I can't find any information on the stock STi drivetrain components and if there are any general limits before breaking them. I have an 04 STi about ready to go with a larger turbo and the last thing I want to do is break what looks like extremely expensive drivetrain parts. I have 70,000 miles on it.
I see high horsepower STi's all over the board but it never seems like much is changed besides the transmission itself or at least gearsets. Are the differentials and axles that stout? Is there anything I can do besides fluids to lessen the chance of breaking these parts?
Thanks
GT4604 is offline   Reply With Quote
Old 03-23-2008, 09:57 PM   #2
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
Default Re: Stock Drivetrain Limits
Do your proper maintennance and the gearbox is pretty much bomb proof. I believe the axles are the first to go, but that's on lots of hard lauches at 500rwhp or so.
Old 04-02-2008, 09:03 AM   #3
Wow I'm impressed.
Old 04-02-2008, 09:15 AM   #4
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
i would agree as long as you treat the tranny right with no dumping the clutch it should be fine!
STI_Mike is offline   Reply With Quote
Old 04-02-2008, 10:14 AM   #5
Car: OBP,2005,STi
There are STi's at MZM pushing over 530whp on a mustang dyno that stock sti's measure at around 200-215 whp that are drag raced and driven like they are stolen on completely stock drivetrains with no issues.
axles are the weak link but plenty of people seem to be pushing serious torque with no issues.
as far as dumping the clultch or slipping it goes.
dumping the clutch will give you some wheel spin and isn't as hard on the clutch and fly wheel as slipping it.
By dumping I don't mean side stepping it at 6000rpm.
AllWheelDriven is offline   Reply With Quote
Old 04-02-2008, 10:33 AM   #6
Car: STIzzle
Fav Mod: Tint
This is what you call not much? Does this sound funny to anyone else?
solovus is online now   Reply With Quote
Old 04-02-2008, 12:08 PM   #7
Car: Blue 06 STI
Fav Mod: FP Green
Send a message via AIM to rabbisti397
"Granny shifting not double clutching like you should."
rabbisti397 is offline   Reply With Quote
Old 04-05-2008, 08:03 AM   #8
Car: 07 euro STi White
Fav Mod: i love them all ! =)
Send a message via MSN to Marteinn
my 02,02 '07 STi only driven 24,000 km gt3076 @ 18 psi only driven 2000km died today :S crap :/
i had 03 sti before just with 3" exhaust, still alive after 100,000 km :S
Marteinn is offline   Reply With Quote
Old 04-05-2008, 08:17 AM   #9
Fav Mod: Motor Mounts
No...not really.
The stock drivetrain is know for being quite robust. Axels go first but I think that is in the design...let them break before something else more expensive goes.
Old 04-05-2008, 08:45 AM   #10
Spiteful Old Codger
In and of itself, I don't think you'll have too much trouble with power. What's going to start busting stuff is power + grip. I have over 1000 hard launches on my stock drivetrain. That's with a variety of tire/wheel combinations from OE up to 275 V710's on 10.5" wheels. My car only has about #360 of torque though.
I do have a twin plate, so it picks up fast, but I also understand how to launch reasonably safely.
Based on anecdotal evidence, I would expect axles to start snapping when you got up into the low-mid 400's, on race tires, launching full-bore, off the tree. For standard-format autoX, you could probably build out a SM car on OE axles. For Pro's or drag racing, you'll probably need to do the axles, and then obviously there will be a greater chance of popping stuff upstream of the axles.
I think it would be totally reasonable to build an upper #400-ish car for launching on race tires and expect to get several seasons out of it before anything went - assuming you can launch effectively.
If you have any weak (defective) links in the chain, they'll probably manifest themselves right up front.
I imagine there's probably some torsional strain on the axles over time. It might be wise to pinstripe them. I would have done that myself if I'd thought about it.
Hope that helps.
Old 04-09-2008, 10:49 AM   #11
Thanks that makes me feel better about this car.
Old 04-09-2008, 10:55 AM   #12
Fav Mod: when it's not blown up
Stock drivetrain (axles/tranny/diffs) ==> YouTube - Jays gt35r STI 22psi in-car pulls + sick launch
My only drivetrain upgrades so far have been upgraded mounts/bushings (besides the clutch of course)... 150+ quarter mile passes and hundreds of hard launches later.
jays05 is online now   Reply With Quote
Old 04-09-2008, 11:35 AM   #13
Car: 96 Time Attack RS
Fav Mod: 06 STi swap
Send a message via AIM to TopSpeed
Use proper gear oil from Subaru. And when you are driving the car hard. Don't miss Shift! We have worked on and tuned countless 500whp+ STi's on stock transmissions. Never an issue. Wrx's on the other hand. Lets just not go there.
Tray M
TopSpeed Inc.
866-94SPEED
TopSpeed is online now   Reply With Quote
Old 04-09-2008, 06:43 PM   #14
Car: '04 WRX STi
Fav Mod: PDXTuning!
I would also be wary of running too much boost for too long (like on a long straight at a race track). If I had it to do all over again, I wouldn't go past 23-24 psi on a stock short block.
If you want to run higher pressure than that, you'd better get yourself some nice purty forged pistons.
wrrrx is offline   Reply With Quote
