IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Drivetrain Components
Old 05-01-2008, 08:31 PM   #16
Car: 05 WRB STi
Fav Mod: Pro Tune
Default Re: Clutch Questions
I figured all you needed was exhaust gaskets. Hopefully it will be done next week.
ilikepie is offline   Reply With Quote
Old 05-01-2008, 08:56 PM   #17
Friendlys Suby
Fav Mod: M&J Modified
What flywheel did you go with? Post here how the clutch feels when you install it. I think I'm going to do the same set-up.
Old 05-01-2008, 09:44 PM   #18
Car: 04 Sti Wrb on Silver
I'm planing on removing the engine instead of dropping the trans. I think that in my part its more easy to just lift the engine out than dropping the trans. I have unlimited tools, but limited space to work with . Do I really need trans fluid? i mean it only has like 10k miles. This is my first clutch change and I want to do it right.
Old 05-02-2008, 12:41 AM   #19
Car: The Vroom-mobile
Fav Mod: JDM Gears
you have to drain the transmission....that and you can drop the transmission with a floor jack if you have a plate for it
Old 05-02-2008, 08:26 AM   #20
But what if instead of drooping the trans I lift the engine out? Lifting the engine seams like an easier way to change it. I mean to lift the engine we just have to undo all the harness and the fuel lines. Plus I don't have the tranny jack but i do have the engine lift lol. That way i don't need to undo the axles and drain the fluid out. Some ppl on there prefer to pull the engine than the trans and it seams it works quite as good as the other way around.
