Old 03-18-2008, 05:26 AM   #1
Car: Silver 05 STi
Fav Mod: Stage 2
Unhappy Mysterious "Clunk"
I have an 05' STi w/40000 miles and I noticed today when I was coasting in neutral under 5mph in my driveway the driverside rear wheel has a pronounced clunk. The suspension is stock I'm running stock tire & wheels as well...
Any ideas?
Misanthrope789 is offline   Reply With Quote
Old 03-18-2008, 05:31 AM   #2
Fav Mod: The Newest One!
Default Re: Mysterious "Clunk"
Sounds like strut clunk. It is your strut sticking and then finally letting go that makes the sound. Mine does it more as the weather gets warmer.
Put a jack under your car, raise up the rear end and either spray or rub down the struts with some kind of lub. It will kill the sound for about a month.
Your only other options are to take the struts off and repack the grease, and even that will only last for a few months. Or you can replace your struts with new ones. The clunk will still eventually come back. Last option is to replace your struts with an aftermarket brand such as Prodrive or Ohlins or go for a coilover.
It is a super common issue
Rear Strut Clunk Log
fourseasonsandles is online now   Reply With Quote
Old 03-18-2008, 05:33 AM   #3
Car: OBP 05 STI
Fav Mod: jazzy eng. ipod adapter :)
It's especially pronounced when going slow over bumpy terrain correct? I have that same sound. Nothing to neccessarilly(sp) worry about is it?
jakillz is offline   Reply With Quote
Old 03-18-2008, 05:41 AM   #4
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
Join the famous rear strut clunk club.....I joined at 11K miles in my 07.
Urban07STI is offline   Reply With Quote
Old 03-18-2008, 07:26 AM   #5
Car: 07 Subaru WRX STi
Fav Mod: Stage 1 (for now)
I seem to have it too in my 07. The clunk is definitely coming from the front though as I exit the garage and pass over a small dip from garage to driveway.
STiProsDoc is offline   Reply With Quote
Old 03-18-2008, 07:47 AM   #6
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
I am getting it too, but it is not my strut....why...because I have coilovers...It is my rear sway bar moving...
MacSTi is offline   Reply With Quote
Old 03-18-2008, 07:58 AM   #7
Car: Silver 05 STi
Fav Mod: Stage 2
Oh man, thats good to hear... I did jack the car up and it is indeed the clunk. I have 40k on the car, do you think Subaru will replace them... Free?
If not what am I looking at for the best solution..? I really like the handling of the stock setup, as I am not auto crossing it so I don't need to dump a crap load of $$$ on aftermarket..
Old 03-18-2008, 10:15 AM   #8
Easiest/Cheapest is to use some sort of lube on the struts once per month. Subaru may or may not replace them. Depends on the dealer. I would guess not with you as you are above the bumper to bumper warranty. You are still under your drive train warranty though.
New struts like the Prodrives or Ohlins will cost about $2k. Coilovers can be slightly cheaper or much more expensive depending on what you buy.
Old 03-18-2008, 01:19 PM   #9
Car: 05' STi
Fav Mod: JDM Fogs
mine gave up at 70K and I drove on them another 10K and ordered up BC racing coilovers. They are a nice ride without being real harsh. You can find mine a twisties comments on the bc coilovers if you just search.
