Old 03-15-2008, 08:40 PM   #1
Fav Mod: 'STi' Licence Plate! w00t w00t
Angry 5th gear problem
When I shift into 5th gear the stick vibrates really hard and it sounds like it grinding i guess. It doesnt do it all the time. Its like I am trying to shift into it without fulling pushing down the clutch, but I am. Its an 04 STi. Any ideas? Its making me pretty pissed...
Old 03-15-2008, 08:57 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
Default Re: 5th gear problem
Just a guess but it sounds like worn synchros to me
Hitman83 is offline   Reply With Quote
Old 03-15-2008, 09:11 PM   #3
Gah is that something that is easy/inexpensive to replace? I hope it is...
Old 03-15-2008, 09:30 PM   #4
Fav Mod: 8cm 20g
If I'm right, the good news is parts are cheap but the bad news is labor will be expensive.
Old 03-16-2008, 05:22 AM   #5
Fav Mod: Synapse FMIC
It's a common problem with 04/05 STI trannys 06+ got upgraded syncros.
Try changing your tranny fluid, and use either the Subaru Extra-S fluid (or whatever its called) or Motul Gear 300. Mine grinds occasionally but by keeping the fluid fresh I've been keeping it alive...
Old 03-17-2008, 09:08 AM   #6
The thing is I just changed the oil. I didnt use Motul Gear 300 or the Subaru stuff but I used a gear oil that was the type called for in the service manual.
