Old 03-15-2008, 12:47 AM   #1
Default weird popping noise coming from rear???
I have this weird popping noise when i'm shifting from the lower gears. You can hear louder when the windows are rolled down. I checked the shocks and the tops are tight. Car has 30k on it with bone stock suspension... Could it be the differential or wheel bearing? It's a loud pop...
THanks,
Sid
sidwin is offline   Reply With Quote
Old 03-16-2008, 02:48 PM   #2
Fav Mod: ACPT driveshaft
Default Re: weird popping noise coming from rear???
If it happens when you're in lower gears and you let off the gas for a bit, I've had the same thing for about 12k miles. Also happens when you do something like back out of a parking space, then shift to first to go forward again. Took the car multiple times to the dealership, no resolution - they said everything was functioning normally. I've either gotten used to it or it went away... I'll have to pay attention next time I go for a drive.
HarlanPepper is offline   Reply With Quote
Old 03-16-2008, 04:51 PM   #3
Car: Silver 05 WRX STi
I got that sound too during shifting. It's most obvious when I shift from 3rd to 4th.
So I took the dealership approach toward this problem and just trying to live with it.
Mohjong is offline   Reply With Quote
Old 03-16-2008, 08:51 PM   #4
Car: 06 Aspen white
Fav Mod: Surfboard in passenger seat
Mine does the exact same thing. I can even feel it a tiny bit through the pedals. I suspect it is the rear diff binding. I plan on taking it in the next time it does it.
SgtKarj is offline   Reply With Quote
Old 05-12-2008, 04:02 PM   #5
I had the same sound and when I put in rear subframe locking bolts it disappeared.
bcblues is offline   Reply With Quote
Old 05-15-2008, 01:12 PM   #6
wow... someone said it was the shocks needing to be relubed... I'll look into those bolts.
Thanks,
Sid
Old 05-26-2008, 09:36 AM   #7
Car: White 04 STI
Mine does a poping sound at low speeds when i hit the gas a little or hit the brakes a little. Sounds like the rear diff. to me. Called the dealer ship, they said its normal to get noise out of the diff. Is it really normal though? i have a full warrenty do think there is a point in having it serviced?
Thanks
ebka33 is offline   Reply With Quote
Old 05-26-2008, 01:18 PM   #8
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
its normal.... that noise is normal along with the 50000 other noises these cars make. Its all good though. at least its fast and handles good
Old 05-26-2008, 02:30 PM   #9
Village Idiot
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
Try replacing your axle nuts.
