Old 02-19-2008, 01:31 PM   #1
Fav Mod: I do meth...
Default Grinding shifts
Just installed a TiC/Kartboy SS and bushings, and I'm grinding my shifts into second on high RPM shifts now. Not huge or violent grinds, just a little grinding sound. I'm not forcing the gearstick in, just a quick snap of the wrist and it's into second. Even if I hold the clutch in and put it into gear, it still chirps the gears.
Is this horrible for the gears if I do it every once in awhile? Do I just need to break the shifter in?
I definately didn't notice this before when I had the stock bushings. I just want to make sure this is the increased NVH that comes along with the bushings and not installation error.
renns is offline   Reply With Quote
Old 02-20-2008, 10:43 AM   #2
Fav Mod: Motor Mounts
Default Re: Grinding shifts
It is not good for the syncros. I wonder if the grind was already there and the bushings did not allow you to detect it...or...you have the shifter hooked up incorrectly. Does it happen 100% of the time or just sometimes?
Old 02-20-2008, 10:47 AM   #3
make sure all the fittings are tight, and in the right place. You're bushings under the car might be to tight. Good luck!
Old 02-20-2008, 11:28 AM   #4
Car: 05 Subaru WRX STi
Fav Mod: Bilstein PSS9 Coilvers
Send a message via AIM to IUSTi
this happens to me too. Only in second though. Sometimes when the car isnt warm, i have a hard time getting it into 1st and 2nd. And when I get it into second i hear a grind while putting it into 2nd.
IUSTi is offline   Reply With Quote
Old 02-20-2008, 11:33 AM   #5
Fav Mod: wingless and mis-fires
Send a message via Yahoo to toogood
careful thats not a good sign...like said above check your work an make sure its properly installed...my buddys synchros is bad as well and the shop said its gonna cost about 1300 to fix...so for a temporary fix he replaced his gear oil
toogood is offline   Reply With Quote
