Old 02-18-2008, 10:53 AM   #1
Car: Silver 05 WRX STI
Default Clutch slipping in 5th and 6th gear
2005 sti, when shifting to 5th or 6th gear clutch will slip 1-2 grand only if RPMs go above 4 grand. There is no slipping of the clutch in all other gears. There is only 28,000 miles on the car I dont think a new clutch is needed already. Any suggestions?
kellie422 is offline   Reply With Quote
Old 02-18-2008, 11:12 AM   #2
Car: 2005 STI
Fav Mod: Methanol
Default Re: Clutch slipping in 5th and 6th gear
I replaced my clutch at 40k miles in my 05 sti and I drove hard
xrocket21 is offline   Reply With Quote
Old 02-18-2008, 11:15 AM   #3
I dont drive hard is there something else it could be?
Old 02-18-2008, 11:22 AM   #4
Car: '05 CGM
Fav Mod: HPDEs
Old 02-18-2008, 01:10 PM   #5
Car: black 04 WRX STi
Check the freeplay at the clutch pedal and at the throwout lever (underneath the intercooler on the driver's side).
Walt is offline   Reply With Quote
Old 02-19-2008, 03:46 AM   #6
Fav Mod: Motor Mounts
Typically if your clutch is slipping it will happen in the higher gears first...so your situation certanly is indicitave of a worn clutch.
One way to tell is to put your car into 5th or 6th gear at a stand still and see if you can get your car to stall. If you dont stall it your clutch is blown.
