Old 02-09-2008, 01:25 AM   #1
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III >=)
Default Went slightly airborne: clunk noise - differential?
Hi everyone,
Earlier this evening, I was driving at speed, but did not notice there was a dip in the road ahead of me. Needless to say, I hit the dip pretty hard. I know what bottoming out a car feels like (as it used to happen with my previous car), but tonight was different.
I didn't notice anything as the car was compressing into the bump, but rather, I heard a loud clunk / click noise as the car was decompressing from the bump (i.e lifting).
Is this the behavior of the differential? I'm assuming the car went airborne for a split second, and as it did, the differential tried to catch up to the rest of the car, thus causing the nose (as it would when one of the rear wheels lifts off the ground).
I checked underneath for a flipped swaybar, and I didn't see anything. Everything looked okay visually.
The car drives normal as far as I know; I will check for anything leaking in the morning.
Anyway, have any of you experienced this before? Am I assuming correctly that the noise I heard was the differential?
Thanks guys, I'm pretty clueless right now.
SD 05 STi is offline   Reply With Quote
Old 02-09-2008, 01:32 AM   #2
Default Re: Went slightly airborne: clunk noise - differential?
I think it may have bottomed out. Like scraped the ground. Or possibly the loud bang of hitting you're bump stops.
Old 02-09-2008, 01:41 AM   #3
hrm, scary. Both my friend and I recall that the RPMs were also increasing for a split second during the decompressing, which was quickly followed by the clunk. This is also another reason why I believe it might have been the differential.
If I did bottom the suspension, it was the very first time I've ever done so. I know repeated bottoming out will most likely ruin the suspension, but can one time do it as well?
Old 02-09-2008, 05:42 AM   #4
Fav Mod: Motor Mounts
Your probably ok...that said a number of problems could occour. Its possible that your struts are blown from the impact...check for leaks. I doubt your diffs are blown. Make sure you check your suspension for bent bits...control arms, endlinks, tie rods, etc. The impact probably wasnt the best thing for your bearings, but they are probably ok.
Anywho sorry to hear...I
Old 02-09-2008, 05:59 AM   #5
abracious
Fav Mod: Track time
The RPM rise was probably from your right foot pushing harder.
the clunk easily could have been metal to metal contact in the rear. the bushings back there are real soft and a large compression could easily deform them enough for you to hear that noise.
i would not worry, as oyu said everything feels ok.
though, if you are really worried, take a look at the rear diff mount bushings and the rear subframe bushings. you could always replace them with TiC's sexy rear end kit.
Old 02-09-2008, 07:20 AM   #6
Fav Mod: All of them
Did you slam on the brakes in the air? Maybe ABS kicked in for a second and made the cluck noise.
Partysub is offline   Reply With Quote
