Old 01-21-2008, 06:36 AM   #1
Default STi Gearbox X-Member Cushion Set
I will be throwing in group n motor mounts and trans mount soon. I noticed that there is also a group n gearbox x-member cushion set. Is there any real point in upgrading to this. I cant picture in my head exactly where they go and if it would be a difficult install. Anyone made this change.
SubySteve is offline   Reply With Quote
Old 01-21-2008, 07:04 AM   #2
Fav Mod: TBE
Default Re: STi Gearbox X-Member Cushion Set
Are you talking about these:
TiC Tranny Crossmember Bushings Turn In Concepts
If so then yes they are a worthwhile upgrade. They stiffen up the driveline more than with just the trans mount.
Old 01-21-2008, 07:20 AM   #3
NIИja
I recently did this. I recommend these bushings.
The stock bushings that are towards the front of the car were blown out, coincidentally. I was going to upgrade them not knowing they were blown out and needed to be replaced. Also, the Kartboy bushings are considerably harder than the stock soft rubber ones. FWIW, I have 45,000miles on the odometer.
Old 01-21-2008, 07:33 AM   #4
abracious
Fav Mod: Track time
It is worth mentioning that you have to remove these to install the tranny mount, so you might as well put fresh ones in there while you have everything apart.
Old 01-21-2008, 10:40 AM   #5
Thanks for the info. I wonder which ones are stiffer.
Old 01-21-2008, 11:12 AM   #6
Fav Mod: TBE
What do you mean which ones are stiffer? Is there another brand besides the ones TIC sells?
Old 01-21-2008, 11:14 AM   #7
NIИja
I may have confused everyone.
I said I have Kartboy ones, but they may actually be TiC. I purchased mine from TiC.
Old 01-21-2008, 11:29 AM   #8
Fav Mod: Most Copied parts on IWSTI!
if they are black they are KB ones. if they are pink they are TIC ones. the durometer is the same.
T
tom@kartboy is offline   Reply With Quote
