Old 12-30-2007, 09:01 AM   #1
Car: 07 obp sti/07 cgm 2.
Fav Mod: Cobb Ap V.2
Unhappy bent something important...
can you tell the difference?
first photo taken from the driver side and the second one from the passenger side, i hit a curb last nite (backing up from the parking lot, i dont even know how that happened cuz i was so slow) and it seems like i bent the driver side inner tire rod ,steering wheel is not centered and lotta tire noise what should i do ? how much would that thing cost to me you think? should i take it to the dealership or buy the part and have it installed else where? any opinions?
thanks
glamcem is offline   Reply With Quote
Old 12-30-2007, 12:33 PM   #2
Car: 1998/2004 LSTi
Fav Mod: carbon fiber shift knob
Default Re: need some help..
tie rod end should cost about 50 bucks. labor at the dealership should be about .9 warranty and 1.3std.
tie rod boot should be about 20. labor should be 1.1 warranty, 1.5std.
make some calls around for labor rates.
ghostdriver is offline   Reply With Quote
Old 12-30-2007, 12:36 PM   #3
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Eeek.
You can replace it yourself with a ball joint/pickle fork. But it definitely needs to be aligned afterwards.
Old 12-30-2007, 06:55 PM   #4
wdb
dances with roads
You are tearing your front tires to pieces with every revolution they make. PARK IT until you can get it fixed!
Old 12-30-2007, 07:20 PM   #5
Default Re: bent something important...
Gives new meaning to the term "toe-in."
Old 12-30-2007, 07:28 PM   #6
Car: 05 OBP STi
Fav Mod: My Right Foot
If the impact was that bad, I'd also have the steering rack checked out on top of everything that was mentioned before.
RdRacer301 is offline   Reply With Quote
Old 12-30-2007, 09:56 PM   #7
I bent the same exact thing on my car a few weeks ago, although the bend is not even close to how bad yours is...
Does anyone know where we can get new tie rods? and where to get them installed? I took my car in for service at the dealership a few days ago and they told me they have to throw it on the allignment machine in order to tell whats wrong... and then go from there....... all they're after is $$$
nevin is offline   Reply With Quote
Old 12-30-2007, 10:08 PM   #8
Car: 05 OBP STi
If the tie rod is bent, it needs to be replaced. And 99% of the time, you need an alignment after replacing a tie rod.
Old 12-30-2007, 11:47 PM   #9
MJM
Car: '07 WRB R1-R
You don't know how it happened? How drunk were you?
MJM is offline   Reply With Quote
Old 12-31-2007, 01:41 AM   #10
Banned
Car: White and Nerdy
Fav Mod: PayPal !!!
heard he looks pretty good in a wig and dress
Nasioc_STi is offline   Reply With Quote
Old 12-31-2007, 06:39 AM   #11
i called the dealership and they told me they need to order the part, and said it takes about 4-5 business day.. is there any difference between the aftermarket part and the oem one..or should i just wait?
Old 12-31-2007, 06:47 AM   #12
Damn! Sorry to see that! Good luck for an easy low-cost repair!
Old 01-06-2008, 10:14 PM   #13
Car: 05 WRX STI OBP
Fav Mod: factory shift light!!! beep beep
this may be obvious but ur gonna need an alignment when ur done but dam dude u must have been wasted and took off in rev or somethin u get three claps for the effort
