Old 12-20-2007, 06:07 PM   #16
Default Re: newly purchased 06 sti? weird sound under car???
Yup, thats normal. The angel of the drive way has ALOT to do with it. The steeper the louder usually..Good luck at the dealer tomorow!
Old 12-20-2007, 06:21 PM   #17
Car: 06 WRX STi
i really appreciate the help man. thanks a lot!
sti702 is offline   Reply With Quote
Old 12-21-2007, 12:47 AM   #18
MJM
Car: '07 WRB R1-R
The popping/clunking could be your rear diff/LSD. Change the oil and be sure to use Subaru diff oil. Just a thought.
MJM is offline   Reply With Quote
Old 12-21-2007, 05:21 PM   #19
Car: 06 WRX STi
yeah im going to get the front and rear diff fluid + the tranny fluid flushed and changed at subaru when i go back for warranty work.
Old 12-22-2007, 06:20 AM   #20
Car: 06 STi
Fav Mod: Stage 2
I am by no means a mechanic, so I can only speak from my own personal experience. I don't believe that you should be hearing any noises when going up a driveway at any angle. Obviously I can't know for sure the exact noise you are hearing, however I experienced the same type of scenario when making right hand turns into an angled driveways. It turned out that I broke my passenger side rear endlink. I would have the stealership check out those endlinks for you while you have it there for service. Just my two cents.
Carciprete is offline   Reply With Quote
Old 12-22-2007, 10:31 AM   #21
Car: 06 STI obp
Fav Mod: My Wife
My 06 does not make these noises and i have owned it for two years!
wrxser is offline   Reply With Quote
Old 12-23-2007, 10:38 PM   #22
Car: UG 07 STI Limited
It is normal...My 07 limited has done it since day 1...It talks about it in the owner's manual
paule858 is offline   Reply With Quote
Old 12-30-2007, 11:33 AM   #23
LSE
Fav Mod: Defi Gauges
I sometimes hear something when I'm in auto but not often and it happened mostly when the car was new. 10 months later, I find that most times i drive in "open" (the bottom DCCD green light). Whenever it is open then I don't hear anything...ever.
the manual talks about these noises but again, it all depends how loud it is. If it sounds like a bullet hit your diff every day then I'd have the dealer look at it.
when I'm in auto I can feel the diff adjusting to changes in the streeing angle. Namely when I'm pulling off a driveway onto the road and accelerating more than normal, I'd feel a slight bump when the front wheels are about 20% from being straight.
also sometimes reversing in auto makes a slight bump at extreme angles.
