Old 12-18-2007, 06:25 PM   #1
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
Default DCCD Green light flashing (can't control DCCD)
I did a search and found that a lot of people had this problem with the ABS sensor as well. However, my abs sensor is not on.
My symptoms:
Car starts up fine, etc.
The bottom dccd light is just constantly blinking green. It won't stop and I have 0 control over the dccd with the buttons inside the car.
The car has been sitting for about a month, I had to charge the battery then started it.
Car has 5840 miles and never in an Accident or something of that sort. Its my weekend car.
Im still under warranty but if there is a quick fix Im all for it.
Im guessing fuse/sensor blew out?
uncle lewie is offline   Reply With Quote
Old 12-18-2007, 06:28 PM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
Default Re: DCCD Green light flashing (can't control DCCD)
no CEL right?
Old 12-18-2007, 06:40 PM   #3
Fav Mod: teH Muff
Originally Posted by Szumita View Post
no CEL right?
No, just the green light blinking and no control over the DCCD on my end.
I drove the car 3.5 miles, and it didn't make any noises, however I will not continue to drive it.
Old 12-18-2007, 06:46 PM   #4
Car: STI
I saved this thread awhile back. hope it helps
Why is my DCCD light blinking green?
ThrillaInManila is offline   Reply With Quote
Old 12-18-2007, 06:59 PM   #5
Fav Mod: teH Muff
Thanks very much. Im gonna call the local subaru dealer and set up an appointment.
Any other info?
Old 12-18-2007, 07:09 PM   #6
Car: STI
No problem. Something probably shorted out or blew a fuse. Keep us updated w/ further info. GL
Most likely to have happened
Originally Posted by scoob View Post
I think that blinking light might have to do with more than your DCCD. I had a short in my rear O2 sensor 2 weeks ago and it blew a fuse. The bottom light on the DCCD started blinking just as you described. Replaced the fuse & the DCCD light stopped blinking. Perhaps something shorted out?
Old 12-18-2007, 07:11 PM   #7
Send a message via AIM to carl s.
I had this and my abs light on for a while this past summer - codes indicated a problem with the right rear wheel speed sensor. weird thing is after I jacked up the car, wiggled the wires around and turned the wheel the lights went off and never came back
carl s. is offline   Reply With Quote
Old 12-18-2007, 07:18 PM   #8
Fav Mod: teH Muff
Crazy. Im gonna leave it up to the dealer, the mechanic who works there is A+, good buddy of mine.
Old 12-18-2007, 07:19 PM   #9
Fav Mod: teH Muff
Thanks again will keep you guys updated.
Old 02-23-2008, 12:57 PM   #10
Car: 06 Sti wrb gold/gunm
Fav Mod: Quick Rack 11.5:1
fixed
TheMearns is offline   Reply With Quote
