Old 12-18-2007, 04:15 PM   #1
Car: 05 WRX STI OBP
Fav Mod: factory shift light!!! beep beep
Default cobb short throw
now i have incounterd an issue with the cobb short throw im still not sure if im right yet but i think so. ok when i put in the shifter all went smooth exept the lose of the pin holding on the reverse cable. well anyway i took it for a test drive and there was a clicking noise coming from the shifter in conjunction with speed and got louder and more frequent like 1st was click----- click-----click and 2nd click---click--- click and 3rd click-- click and so on so i think as the shifter moves closer to the spot where the rev. cable comes in through the boot so i adj. the shifter to its top hieght and all went away along with the short throw so i think when the shifter is adj. down i think the cable is being pushed down to bind up and hitting the drive shaft i will check it out later but what do you guys think
wsirianni is online now   Reply With Quote
Old 12-25-2007, 03:22 PM   #2
Car: 05 STI
Default Re: cobb short throw
i had this same problem? and your right i got under the car and found some chaffing on the wire. had to use some zip ties to kep it up.
1slwsti is offline   Reply With Quote
Old 12-25-2007, 03:48 PM   #3
Iron Fisted
Fav Mod: Sparco seat
I've heard of this problem too. Some zip ties should do the job
Old 12-25-2007, 04:25 PM   #4
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
in the cobb instructions is mentions about needing to put zip ties down underneath to prevent this
Old 12-25-2007, 07:29 PM   #5
Car: 05 STI
who needs instrustions
Old 12-26-2007, 03:02 PM   #6
Car: 06 STI
Fav Mod: Prodrive oval tip
it's probably your reverse lockout cable getting shredded by the drive shaft under your car
Old 12-31-2007, 11:47 AM   #7
No Rice
Car: 06 OBP STi
Fav Mod: Brake dust
Yeah you need zipties. Go to Cobb website and find the PDF file with instructions. Its pretty detailed and pretty much tells you what to do.
Seppo is offline   Reply With Quote
Old 01-06-2008, 10:11 PM   #8
Car: 05 WRX STI OBP
yeah i finaly got under there and tied it out of the way so i could adjust it all the way down well not all the way because it wont go into second when al the way down but man is it short me likey
Old 01-07-2008, 06:22 AM   #9
Car: 05 STI
the shifter is weird because the taller it is (height wise) the shorter the throw. i would rather see it sit lower but its whatever.
