Old 11-29-2007, 05:58 PM   #1
Car: Silver 07 WRX STi
Send a message via AIM to i<3myawd
Default Knocking noise while in lock...
when i set my diff to lock and i turn i always hear this odd noise, i've heard its the inside wheels trying to travel the same distance as the outside ones. however i just installed a tbe and now the noise is abnormally loud, and even happens on straightaways... any idea what might be causing this?
i<3myawd is offline   Reply With Quote
Old 11-30-2007, 04:58 AM   #2
Reasonable
Fav Mod: correct grammar
Default Re: Knocking noise while in lock...
When the diff is locked, the drivetrain makes lots of noises. Fact of life.
The diff should only be locked when traction is at a minimum. Don't do it on dry or even wet tarmac. It's typically used for ice/snow and gravel/dirt/mud.
As far as the noise change, check the hangers and fasteners for the exhaust?
Old 11-30-2007, 10:34 AM   #3
so the noise is normal? thing is when i have it in auto, it also makes a slight noise when i hit sharp turns/u-turns
Old 11-30-2007, 10:51 AM   #4
Reasonable
Also normal, though if you're concerned, you should take it to a mechanic and make sure.
Old 12-01-2007, 07:59 AM   #5
hah if i take it to subaru wont they just blame the "modified exhaust?"
Old 12-01-2007, 01:52 PM   #6
Car: 07 STI
touche
kt3130 is offline   Reply With Quote
Old 12-01-2007, 01:58 PM   #7
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Read the owners manual man. You're not supposed to have it in lock on dry tarmac. The noise is your center diff begging for you to stop.
Old 12-01-2007, 07:41 PM   #8
The Stig II
Fav Mod: EFI Logics tune
^^^that^^^
jnprn2003 is offline   Reply With Quote
Old 12-02-2007, 06:01 AM   #9
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
If you've ever driven a car with an LSD before, you know that it won't like tight turns. Our cars have *three*!
Old 12-02-2007, 06:28 AM   #10
abracious
Fav Mod: Track time
the noise is your center diff slipping to allow the front and rear tires to rotate at a different speed. the center diff does not use clutches like the f&r, it uses a magnetically controlled pack that changes the amount of slip, thereby changing the torque split. When you turn too tightly, ball bearings in the diff have to slip past their cams. This is the sound you hear.
This is not a good thing to do all the time.
Old 12-02-2007, 01:40 PM   #11
wdb
dances with roads
I had my center diff set two clicks back from full lock last night, during my commute home on empty, snow-covered roads. It was really cool because I could hear the center diff working. Even with snow on the surfaces though, when I was making parking lot maneuvers (low speed, tight turns) the diffs were barking at me.
Old 12-03-2007, 10:54 PM   #12
Funny, I was running mine full rear for a little, and noticed the noise more from the front during slow parking lot turns, thought it was my steering rack slipping on my new Whiteline bushings but hoisted her and nope, everythings fine. Just ended up figuring it was the diffs doing their thing. Leaving it in auto for severe parking lot manuevers from now on.
ikoinu is offline   Reply With Quote
