Old 11-21-2007, 04:39 PM   #1
Car: 06 STI (blue)
Fav Mod: car itself ;)
Default clutch ajustment >?
Hi ,just curios how to ajust a clutch cable ,without going to dealer got 9 K miles on the car ,and it feels like i got 3 times less clutch than i had when car was brand new :/
tnx !
Want3D is offline   Reply With Quote
Old 11-21-2007, 05:01 PM   #2
Banned
Car: White and Nerdy
Fav Mod: PayPal !!!
Default Re: clutch ajustment >?
check the fluid there isn't a clutch cable .
Nasioc_STi is offline   Reply With Quote
Old 11-22-2007, 03:43 AM   #3
Car: 05 Subaru WRX STi
Send a message via MSN to arnif
The clutch isn't adjustable.
arnif is offline   Reply With Quote
Old 11-22-2007, 05:45 AM   #4
Banned
Fav Mod: PayPal !!!
but the peddle is .
Old 11-22-2007, 01:29 PM   #5
Car: 06 STI (blue)
fluid is fine ....
its just a feeling like i have a little bit of if compare to new car ....
Old 11-22-2007, 01:30 PM   #6
Car: 06 STI (blue)
how do i do that >??? just tighten it from inside of the car right >???
any 1 else have this >? or all of you have same feeling since car was new >? :/
tnx !
Originally Posted by Nasioc_STi View Post
but the peddle is .
Old 11-22-2007, 08:03 PM   #7
You can adjust the free play by loosening the lock nut and adjusting the lever arm - get under there with a 14mm wrench and you should be able to figure it out. It helps to loosen up the throttle pedal first to get it out of the way. However, if the free play is properly adjusted and you still get engagement way high up in the throw, it's time to start shopping for a new clutch.
