Old 11-17-2007, 03:55 PM   #1
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Default Whiteline sub-frame lockout bolt torque specs?
just installed the whiteline bolts. I followed the instructions, which said to loosten the 4 main rear subframe mounting bolts. I installed the lockout bolts and torqued them to 66ft/lbs like the directions said. But the directions didn't say the torque specs for the 4 bolts I loosened. I used my torque wrench to loosten them and they took about 100 ft/lbs to loosten. I only torqued them back to 66ft/lbs but that doesn't seem like enough. I've searched but cannot find a torque spec diagram for this assembly.
Old 11-17-2007, 05:17 PM   #2
Car: 07 STI
Default Re: Whiteline sub-frame lockout bolt torque specs?
anyone?
Old 11-17-2007, 05:22 PM   #3
Car: '06 STI
Fav Mod: air freshener!!!
What size are the threads? (not the wrench size...)
NOTE: you will likely need an alignment after this instal. I was told not to run these as it eliminates the rubber isolation of the subframe which may cause cracks but after almost 30k miles, I have no problems and i like the better feel/control.
Old 11-17-2007, 06:11 PM   #4
Car: 07 STI
I have no idea. I figured someone should have the diagram.
I planned on an alignment soon. As for the cracking, where/what exactly cracks?
Old 11-17-2007, 09:00 PM   #5
Car: 07 OBP/Gold STi
Fav Mod: DomTune & MD Whisper
don't know about the TQ setting, but can you give us a review after the install? i have been thinking of upgrading some of my rear diff bushing/hardware and would like to know how much these help...
Loubaru is offline   Reply With Quote
Old 11-17-2007, 09:13 PM   #6
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
I put in the lock bolts the same time I did my lateral link bushings. I can't say just how much of the end result was due to just the bolts, but if you're going to be under the car anyways, it's worth putting them in.
With the lat-link bushings and bolts in, the rear of the car is much more sure-footed. Bumps while turning are absorbed by the suspesion as they should be rather than causing flex and throwing off your alignment. Going through turns, the rear seems to track a tighter circle.
These are definately worth doing. The bushings and bolts really make the rear of the car feel like it should havge from the factory.. I cna't wait to get the rest of them done.
Old 11-17-2007, 09:22 PM   #7
Car: 07 STI
I just installed a bunch of bushings all at once. I plan on doing a review on all the new stuff soon.
Old 11-18-2007, 03:34 PM   #8
Car: 04 WRX STi
Fav Mod: Whiteline Everything
Send a message via Yahoo to scotty20bsp
Tq is 66 ftlbs, did you torque them with the tires on blocks with the full weight of the car on the subframe? Thats the key. I did the whole TIC sexy rearend-clunk stopper mod on mine. Its great ,way solid.
scotty20bsp is offline   Reply With Quote
Old 11-18-2007, 04:33 PM   #9
Non-Reformed Meth Addict
Car: '06 WRB
I've had the lock bolts installed for over a year and it really makes a nice difference in how the rear of the car feels. I've also taken them out a few times to grease them and check for any issues and none so far. The bolts with the Klunk Killer kit makes a perfect combo.
Old 11-18-2007, 05:44 PM   #10
GT R US
little ricky absolutely refused to install these on cutn edg; this from a guy who hacked almost everything else on the car with childlike enthusiasm. i didn't feel like arguing with him.
Old 11-18-2007, 07:03 PM   #11
Car: 07 STI
The whiteline bolts are 66ft/lbs. The two bolts beside them that I had to loosten are actully 96ft/lbs(according to te service manual). I also did the sexy rear-end.
so far I'm liking it.
I have one question to those who have installed the bolts. I torqued them down to 66ft/lbs and there is still about a dime size thickness between the surface of the bolt head & the subframe. Is the bolt supposed to sit snug to the subframe? I also noticed a metal on metal clunk while downshifting, which feels like those two surfaces meeting. Any thoughts?
to whoever asked about how I installed them, I just slid my skinny a** under the rear with the car parked in the garage.
Old 11-19-2007, 04:53 AM   #12
Black Dragon STI
Mine had the same gap. When I was back under the car installing my catback, I checked them and I think they are now flush. So it may take a small amount of settling. I should re-torque them and see if I can get them deeper. But I don't think it's a big deal.. The Whiteline bolts have a really deep collar for the subframe, it's not going anywhere.
I did mine when I was helping document THIS how-to.
Old 11-19-2007, 05:55 AM   #13
Car: 07 STI
So did you get the metal on metal clunking I described? I know the collar is plenty long and is beveled. If I could watch what's going on back there while shifting through the gears I would probably see the subframe compressing slightly against the chassis then decompressing and bottoming out on the lockout bolt head. At least this is what it feels and sounds like from the drivers seat. I know the bolts are to prevent the subframe from side to side movement, and I'm sure they are doing a good job at that, but if they are making all this noise it bothers me. Maybe it will just take time to set like you said. I just want to make sure I didn't do something wrong. Everytime I make an aggressive shift I get the clunk.
Old 11-19-2007, 10:32 AM   #14
Car: 07 STI
anyone else have this problem?
Old 11-19-2007, 04:00 PM   #15
Car: 07 STI
bump for answer.
