Old 11-17-2007, 09:42 AM   #1
Fav Mod: COBB Stage 1!
Default Signs of a failing front diff?? (UPDATE - bad bearing in drivetrain)
Hi All,
I've started to notice a howling noise coming from the front of the car. It's only audible when I've got my foot on the gas pedal. When I lift, the noise goes away. Is this the sign of a failing front diff?
The front diff and tranny share the same fluid reservoir, right? My tranny fluid is full, but the dealer (during the 60K service about 1200 miles ago) only filled it half full before I drove it home. I noticed a whining noise coming from the tranny, checked the fluid, and had them add more.
If it's their fault, I'll be really pissed.
windmill is offline   Reply With Quote
Old 11-18-2007, 11:09 PM   #2
Car: WRB 05 wrx STi
Send a message via AIM to Jays05WRB
Default Re: Signs of a failing front diff??
Howling noise? Hhhmmm......Is your fluid at full now? If so is it still making the sound?
Jays05WRB is offline   Reply With Quote
Old 11-18-2007, 11:18 PM   #3
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Howling noise....hmmm.....Mine has one too...but it's pretty common...
Old 11-18-2007, 11:47 PM   #4
Car: WRB 05 wrx STi
Just wondering what rpm does it howl at? Dose it affect the performance?
Old 11-19-2007, 09:44 AM   #5
The howling is definitely a new noise. It sounds almost like a cross between gear whining and driving through water (almost like a hissing... but I don't think it's turbo related). Strange description, I know, but those are the two sounds that come to mind when I hear it.
It happens at around 3K RPM and higher. Tranny fluid level is full. It happens under acceleration and moderate throttle. It goes away with low or no throttle. When I let off the throttle after acceleration, that transition feels a lot more abrupt.
Isn't diagnosing noises over the internet fun?
Old 11-19-2007, 09:46 AM   #6
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
maybe a slight boost leak?
any performance change?
Old 11-19-2007, 10:38 AM   #7
No real performance change. Car can still hit full boost.
Old 11-19-2007, 10:59 AM   #8
Car: WRB 05 wrx STi
Does it kinda sounds like a pinging sounds or sort of like a hint of grinding?
Old 11-20-2007, 10:46 PM   #9
Car: WRB 05 wrx STi
Does the howling happend when the car is hot or cold? Maybe both?
Old 11-20-2007, 11:08 PM   #10
Trader Rating: (14)
do you have any bushings?
Old 11-20-2007, 11:25 PM   #11
Car: 06 Aspen White STI
Fav Mod: Defi's
Is checking the tranny fluid level easy? I think I may need to do this.
Iguana is offline   Reply With Quote
Old 11-25-2007, 06:25 AM   #12
Checking tranny fluid is really easy. When the car is cold, pop the hood and look down near the turbo. On the tranny case you'll see a small dipstick that you can use to check the fluid.
Old 11-25-2007, 06:33 AM   #13
I took it to the dealer, and they think a bearing in the rear diff is starting to fail (could be in the transmission, too... hard to tell). Tranny and rear diff fluid are very clean, though, which is good... no metal flakes or anything.
Know what Subaru wants for a rear diff? $1895 I think I'll wait until I'm damn sure which bearing is failing, and then find a good transmission shop and have them replace it (and maybe the clutch at the same time).
The car is only 1800 miles out of powertrain warranty. This sucks.
Anyone know a vendor on this site that sells Motul products? I think I'll toss some in my trans and diff and see how far I get.
Old 11-25-2007, 07:20 AM   #14
Car: 07 WRB WRX
Fav Mod: rally school
Send a message via AIM to shockey` Send a message via MSN to shockey`
Default Re: Signs of a failing front diff?? (UPDATE - bad bearing in drivetrain)
Motul Lubricants
shockey` is offline   Reply With Quote
Old 11-25-2007, 07:30 AM   #15
100% More Wingless
Car: 05 STi + 08 OBXT
Fav Mod: baby seats
Did you ask the dealer if they could pro-rate the repair for you, as the car is stock and only -just- out of warranty?
