Old 11-25-2007, 10:03 AM   #16
Fav Mod: COBB Stage 1!
Default Re: Signs of a failing front diff?? (UPDATE - bad bearing in drivetrain)
Originally Posted by Datadatum View Post
Did you ask the dealer if they could pro-rate the repair for you, as the car is stock and only -just- out of warranty?
I'll try that. They said that if it's in the differential, they won't tear it apart to replace a bearing (not sure why??). They'll want to order a whole new rear diff. It might be cheaper for me to go somewhere that will only replace what's needed.
windmill is offline   Reply With Quote
Old 11-25-2007, 10:06 AM   #17
Originally Posted by shockey` View Post
Thanks!
Old 11-25-2007, 03:24 PM   #18
Car: WRB 05 wrx STi
Send a message via AIM to Jays05WRB
Easy fix? Could it be fixed with the right lub?
Jays05WRB is offline   Reply With Quote
Old 11-25-2007, 07:53 PM   #19
I hope so. What really torques me is that I bet I would have heard this and talked to the dealer if I had my winter tires put on earlier (read: before the warranty ended). They run so much quieter than the summers that the strange noise became audible.
Oh well. Maybe I should trade it on an '08. They also have a nice Forester XT Sports on the lot.
Old 11-28-2007, 10:33 PM   #20
Car: WRB 05 wrx STi
Replacing transmission bearing, is it a easy fix? How much? Are you on stock fluids (just wondering)?
Old 11-29-2007, 12:18 PM   #21
The 60K service was done with stock fluids. I'm about to toss Motul fluid in the rear diff. I have no idea how much a transmission bearing would cost. I bet the bearing is cheap, but the labor is an arm and a leg, and then some. Rough estimate, anyone?
Old 12-04-2007, 09:07 PM   #22
Car: WRB 05 wrx STi
Hey windmill, when your synchros went out was it always making the howling sounds (hot/cold or both)?
Old 12-05-2007, 09:49 AM   #23
Fav Mod: jailbreak
wow , no mods at all?! we got our cars in the same month hope it just the fluid. when i did my 30k i worked at the dealer. used their fluids ,i started to get some new sounds. no problems 20k miles later though
munky69 is online now   Reply With Quote
Old 12-05-2007, 08:59 PM   #24
Car: WRB 05 wrx STi
any updates?
