Old 11-13-2007, 05:04 PM   #1
Fav Mod: Ricer Flyby
Default Hard shifting into gear
Ive just started to notice lately that its getting kinda hard to shift into gear mostly in 1st and 2nd but its getting harder in every gear. This doenst just happen when teh car is cold but it happens when the car is warm too. Does anyone have any ideas as to what may be causing this or anything i can check? Thanks!
Old 11-13-2007, 05:09 PM   #2
Car: 06 STi Spec C
Fav Mod: The STi experience
Default Re: Hard shifting into gear
Check your trans fluid level (dipstick under intercooler). My car was having the same problem and I had the dealer check it out but they found nothing wrong. Ever since then the car has been perfect. I'm guessing your trans fluid is low or it needs to be changed.
06SpecC is offline   Reply With Quote
Old 11-13-2007, 05:13 PM   #3
already? i only have 9300 miles on my car!
Old 11-13-2007, 05:17 PM   #4
Car: 06 STi Spec C
Yea I had 3900 miles when my trans was acting up also! The STi trans is very picky (and supposedly they are sometimes low on trans fluid from the factory), so if you could bring it to the dealer and let them check it out it would be a good idea. It may not need a flush but your best bet is to check the trans fluid level. I'm currently at 5800 miles and my trans is perfect.
Old 11-13-2007, 05:20 PM   #5
hum ok i'll check my fluid when i get home from work today
Old 11-13-2007, 06:12 PM   #6
so just in case is the only place to get the gear oil the stealership?
Old 11-13-2007, 07:43 PM   #7
Muller Chevrolet
Fav Mod: a new 08 STi
yea if you need to top it off.
Old 11-13-2007, 07:48 PM   #8
how would i come about topping it off?
Old 11-17-2007, 12:46 PM   #9
Fav Mod: Driving School / Trunk swap (no attention ftw)
warranty should cover that...especially at your mileage, and if you've never touched the fluid.
Tell them your not interested in paying, and if they won't fix it, you'll drive it till it breaks, then they'll have to fix the whole ****ing thing.
Jesse
mgsm666 is offline   Reply With Quote
Old 12-15-2007, 07:54 PM   #10
Car: '04 WRB STi
Fav Mod: Bushings! TIC, FTW
I was using Valvoline for 20,000 miles in my 6MT 04 STi tranny; but was having problems with it shifting smoothly when cold... light grinds, difficulty getting it into gear, etc.
Just switched back to the stock "Extra-S" tranny fluid and it made my tranny shift like butter. A+ recommendation from WJM!
19-Kilo is offline   Reply With Quote
