Old 11-11-2007, 04:21 PM   #1
Car: 2005 STI
Fav Mod: Methanol
Default Please help me troubleshoot my toasted ACT 6-Puck
Today, the clutch in my sti went
ACT installed in march at 43k miles
Currently at 61k miles
Middke of an auto-x it wouldnt go into second. Got it in and then at the finish, car died at the stop. Wouldnt start in gear. Put in neutral when car off and it would start, but not go into gear.
I started the car in gear and limped it home revmatching. (160 miles on the highway)
No issues, the clutch just wont disengage.
-Pedal feels fine
-Fluid if fine (bled a bit and no air)
-clutch fork moves normal
-no sound when it went
-no rattles when it drives
wtf?
I hope ACT warranties it. Im tearing it apart tomorrow.
Any advice on this is GREATLY appreciated. Putting the cluch in was a WHORE and I am NOT looking forward to pulling it back out in november in an unheated garage
this sucks
xrocket21 is offline   Reply With Quote
Old 11-11-2007, 06:08 PM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Please help me troubleshoot my toasted ACT 6-Puck
What do you have done to the car that requires a pucked clutch?
Old 11-12-2007, 02:41 AM   #3
Car: 2005 STI
Fav Mod: Methanol
Catless, protune, Perrin ebcs, colder plugs, protune, meth injection and thats it
Stock turbo/IC/inj
307/372 at the wheels.
I auto-x a lot and The stocker slipped at 40k ish
I wanted something that I would never have to worry about that was PLENTY strong.
THink ACT will warranty it? Think its even the clutch?
I dont know what would happen that that clutch will still hold, the dedal feels fine, but clutch won t disengage.
Pedal feel and fork movement tell me clutch hydraulics are working okay and TO bearing is okay. Something internal in the clutch broke making it not able to disengage?
Old 11-12-2007, 06:20 AM   #4
Trader Rating: (53)
Stock turbo/IC/inj
How do you know the TOB is OK? I think your best bet is to tear it apart and have look. It could be any number of things.
Although - I'm assuming you checked all the external hydraulics first...
Old 11-12-2007, 06:39 AM   #5
Car: 2005 STI
Fav Mod: Methanol
Clutch has bluid and a small bleed showed now air. Pedal feels fine and I can see the clutch fork moving.
Id hate to pull the tranny and find I didnt need to, but Appears I have too. Im pretty sure its clutch related unless you can point me in a direction otherwise.
I need help pushing it into the garage, then Ill get started on it in a min.
Thanks for the help, Im feeling pretty ****ty here.
Old 11-12-2007, 06:42 AM   #6
Car: 05 STi CGM
Fav Mod: whiskey tango
One of the springs on the clutch hub could have popped out or be broken, or the throwout bearing could have disengaged from the pressure plate(giving you pedal pressure but no ability to disengage the gear); these are the first things that come to mind. You really are going to have to take it appart to find out.
Old 11-12-2007, 06:54 AM   #7
Car: 2005 STI
Fav Mod: Methanol
Okay, thanks, that basically what I was getting at. Ill take pics of what I find.
Wish me luck.
Old 11-14-2007, 04:41 PM   #8
Car: 2005 STI
Fav Mod: Methanol
And so it begins again....
It is SERIOUSLY crammed into this tiny garage, like 4 inches clearance on the drivers sided, folded in the mirrors to get it in.
ITS TIGHT
Emptying out the engine bay
Some fuel to keep me going.....
Underneath it all
So far:
-Pushed into garage
-Up on Jackstands
-Removed front wheels
-Pulled Intercooler
-Removed starter
-Removed clutch slave
-Removed pitch stop
-Removed exhaust and downpipe
-Removed driveshaft
-drained tranny of 8 month old royal purple
Tomorrow:
-remove shift linkage
-droop suspension
-pull axles
-Unbolt tranny and drop out
-Unbolt clutch and see WTF went wrong
-wait for new Exedy from IMPORT IMAGE RACING
Old 11-15-2007, 03:01 PM   #9
Car: 2005 STI
Fav Mod: Methanol
Default How many miles should an ACT 6-Puck Last
307 whp
372 wft/lbs
Old 11-15-2007, 03:19 PM   #10
Fav Mod: Track days!!!
Default Re: How many miles should an ACT 6-Puck Last
A 6-puck should really only be used for a track car. ACT has an Xtreme street disc don't they?
05cgm is offline   Reply With Quote
Old 11-15-2007, 04:55 PM   #11
Fav Mod: $50 dr725 and all my pnp items
Thats rough I hope it works out for u. I remember when I did my clutch alone and in a small garage, what a pain. I pulled the engine forward instead of removing the trannsmission though which came apart and went back together fairly smooth, using just a floor jack is what made things tricky.. I'm using ACT's streetdisc with about 400whp and 40,000 miles now. Good luck.
Mycues1982 is offline   Reply With Quote
Old 11-15-2007, 05:06 PM   #12
Car: 2005 STI
Fav Mod: Methanol
i made it 8 months and 20 k miles and Im not impressed.
I have an exedy 3 puck on the way and I am reconsidering....
Old 11-15-2007, 08:18 PM   #13
Car: WRB 02 WRX
exedy FTW!
wrbbugeye02 is offline   Reply With Quote
Old 11-15-2007, 11:43 PM   #14
Car: 05 STi CGM
Coming from and ACT 6puck to an Exedy 3puck is like going from bad to worse in terms of longevity. Unless your car is never daily driven you really dont need a puck clutch. Stick with a disk like ACT or RPS. For what its worth I have an RPS Street Max that has lasted me 36k miles, which for me is 10k miles longer than the stock clutch lasted.
Old 11-16-2007, 05:12 AM   #15
Car: 2005 STI
Fav Mod: Methanol
Jesus. My ACT lasted 20k miles with moderate use.
You the think Exedy will last even shorter? The thing only made it 8 months. I cant be doing clutch swaps twice a year. You really think I should go back to organic?
I want something that is strong and will last.
