Old 10-31-2007, 03:38 PM   #1
Car: CGM '07STi
Fav Mod: na
Default Shifter Bushings
I have a 2006 obpSTi with the fact. short shifter and was just wondering if changing out the stock bushing for kartboy or cobbs will make a big diff? any pros and cons to doing this???thanks guys
tsenekos'05sti is offline   Reply With Quote
Old 10-31-2007, 03:46 PM   #2
Fav Mod: TiC AST Coilovers!!!
Trader Rating: (88)
Default Re: Shifter Bushings
they do make a big improvement! While you're in there wrenching, you might as well get the rest of the shifter bushings found at Turninconcepts.com
WC LATHE WERKS is offline   Reply With Quote
Old 11-01-2007, 08:42 AM   #3
wdb
dances with roads
Ditto all of that. Pick up one of the TiC kits and you will not regret it. Search this forum for the eleventy bazillion testimonials.
wdb is online now   Reply With Quote
Old 11-01-2007, 08:54 AM   #4
Fav Mod: TBE
Yea this topic has been discussed hundreds of times. I don't think I've ever seen a negative answer about it.
Old 11-01-2007, 08:58 AM   #5
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Here is what you need: TiC 06+ Holy Shift Set Turn In Concepts
just did mine, world of a difference. No more side slop.
Old 11-01-2007, 09:16 AM   #6
Trader Rating: (50)
Actually, check the linkage color under the car. If the linkage core is gold then you want the 04/05 setup. If the linkage core is dark green you want the 06 setup.
Old 11-01-2007, 09:37 AM   #7
Car: CGM '07STi
Fav Mod: na
thanks guys how easy is the install with the tic kit ??? thanks again
Old 11-01-2007, 11:15 AM   #8
Fav Mod: TBE
Depending on how mechanically inclined you are it could be anywhere from an hour to 3 hours. It really depends on you.
But here are the install instructions from TICs website:
Turn In Concepts
I would suggest reading the individual install guides like the Front Klicky Kit, Rear Klicky Kit, and Subaru Lever Pivot Bushings. Each of those will encompass the whole kit but it will allow you to focus on each bushing individually... and it has pictures!
Old 11-05-2007, 05:24 AM   #9
Just did this to my 07 over the weekend. I did the TiC shift kit with the KB shifter. Best mod I've done to the car. The shifts feel EXCELLENT. It gets rid of the bucking shifts completely.
