Old 10-15-2007, 11:06 AM   #1
Car: 07 Subaru WRX STi
IWSTI Addict since: Sep 2007
Default Is shifitng in an STI different than normal cars???
Ive heard from some people that shifting in an STI is different from a normal manual car. Ive been practicing driving a manual for about a week now so I am very new to it. I will be getting an STI within a month and I was just wondering if there are any differences? Are the gears longer or shorter? The Clutch? Anything. Thanks
liquid91184 is offline   Reply With Quote
Old 10-15-2007, 11:13 AM   #2
dex
Car: 07 CGM STi
Fav Mod: Stage 2
IWSTI Addict since: May 2007
Send a message via AIM to dex
Default Re: Is shifitng in an STI different than normal cars???
i've noticed it takes more practice and skill to drive a STi rather than a stang, Z, and a few others
dex is offline   Reply With Quote
Old 10-15-2007, 11:13 AM   #3
Car: '07 SWP STi
Fav Mod: NEW BRAKES!!!
IWSTI Addict since: Feb 2007
Send a message via AIM to Kickstand
1.Push in Clutch
2.Put in first gear...Drive
3.push in clutch
4.Shift to second gear...drive.
5.Rinse and repeat steps until you reach sixth gear. Downshift accordingly
A stick is a stick buddy. Everyone is a little different. Sti's are notchy but they still shift just like anthing else
Kickstand is offline   Reply With Quote
Old 10-15-2007, 11:15 AM   #4
Car: '05 CGM
Fav Mod: HPDEs
IWSTI Addict since: May 2006
No significant differences. Howver, there are some minor differences.
Minor differences:
1. 6 speed versus typical 5 speed.
2. Close ratio gear box versus typical over-drive gear box.
What that means is that in a typical 5 speed over-drive gear box, you'll do a lot of driving in 3rd and 4th gears and typically only use 5th gear when on the interstate. In a 6 speed close ratio gear box, you'll be using 3rd, 4th and 5th like you would 3rd and 4th in the earlier scenario. That means you'll be doing more shifting and making clean 4th to 5th shifts is a litle more challenging then making a 3rd to 4th shift. Similarly, making a 5th to 4th downshift is more challenging than the 4th to 3rd downshift simply because of the shift pattern of the transmission.
Gary
Old 10-15-2007, 11:15 AM   #5
DOMINATOR
Fav Mod: Strut Clunk
IWSTI Addict since: May 2005
I'd say these cars are rather easy to drive compared to your normal stick shift. I know this car is easier than my old accord was.
Old 10-15-2007, 11:18 AM   #6
Car: 05.75 WRX STI
Fav Mod: Protune
IWSTI Addict since: Feb 2004
Send a message via AIM to stickytires
It is different. You can't just dump the clutch like a FWD or RWD.
I can't downshift into 1st most of the time on a slow roll. Sometimes it won't even go into second until the right speed is reached. Something built in that prevent it from happening.
Drive it like a FWD or RWD and say bye bye to your drivetrain.
stickytires is offline   Reply With Quote
Old 10-15-2007, 11:35 AM   #7
Fav Mod: TBE
IWSTI Addict since: Sep 2006
I noticed that the clutch was a little more touchy than I was used to. It took me a while to get out of some of the bad habits that I had from driving some of the more lenient cars like Civics and such.
Old 10-15-2007, 05:04 PM   #8
Car: Silver 05 STi
Fav Mod: driving school
IWSTI Addict since: Jul 2007
Well if you're going to buy an STi in a month, I would HIGHLY suggest you TEST DRIVE one before you dump lots of MONEY into a car you've never driven. You'll learn more if you just drive it.....
ScubaSmith7599 is offline   Reply With Quote
Old 10-15-2007, 05:20 PM   #9
IWSTI Addict since: Aug 2006
Trader Rating: (14)
it should be the same other than the slight pause from clutch delay valve
Old 10-15-2007, 05:51 PM   #10
Car: << 07-STi >>
Fav Mod: A Good Wax Job
^^^^ Good Point.
Once you test drive the Sti.....learn to-
Keep the "revv"s" up a "little" higher with the smaller engine....
Performance driving is a little different than normal- put in Clutch shift to second deal..Search is your friend here...READ...READ...READ....
STIVendetta is offline   Reply With Quote
