| Authorized Vendor Car: 06 B-SPEC Legacy wit Fav Mod: AP Pedals and Motons Location: SEE the NEW SITE www.GTWO Posts: 1,120
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Recaro Speed ![]() ![]() Standard Features: * Belt guides 4-point or 3-point seat belts can also be used * Specially formed shoulder support for excellent lateral hold * Distinctive pronounced seat and backrest bolsters for lateral support even in sharp corners * Integrated headrest for head protection * Seat back release on both sides for simple operation * Recline adjustment on both sides for comfortable operation * Individual lumbar support by special cushion element for ergonomic fatigue-free seating $699 ($759 for 5-point compatible model) Recaro Pole Position ![]() Standard features: -integrated headrest for head protection -lordosis cushions for individual support of the spinal column -specially designed shoulder support for excellent lateral hold (extras available at extra cost) -seat shell of glass fiber-reinforced plastic material (GRP) -well-defined seat cushion and seat back bolsters for good vehicle control in all driving situations. -belt guides for a 4-, 5- or 6-point belt. $649 Recaro profi SPG ![]() Standard features: -friction grip surface in the shoulder and seat area -well defined side contours for excellent hold in fast curves -seat belt design for four, five and six point -belt guides for a 4-, 5-, or 6-point belt Available in Velour Black ONLY $799 We carry a full line of Recaro seats, call us for pricing and availability! This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by GTWORX.com; 08-10-2006 at 01:06 PM. |
| | #2 |
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Sparco Evo ![]() • Cushions and back can be customized in various colors. • Back and cushions can be removed to customize the back rest, height of the leg rest and the cushion padding. FIA homologated Available in Black, Blue, Navy and Red $669 Sparco Pro 2000 ![]() FIA homologated Available in Black, Blue, Navy and Red $699 Sparco Monza ![]() Features include: • Tested and Approved to ECE 17 (Europe) and FMVSS 208 (USA) • TUV Homologated. • Netspacer and Micro-Fiber Fabric. • Micro Adjust reclining mechanism. • Injection Foam Molded. • Lateral Support. • Quick Tilt System. $699 We carry a full line of Sparco seats, call us for pricing and availability! |
| | #3 |
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Takata 4-Point Harness (short) ![]() The 3” wide racing harness designed for mounting in a 2-seater car is the racing gear of choice when high precision driving comes first. Safety equipment comes standard with cam lock buckle device, belt length adjusters, fasteners for attachments to eye bolts and four short eye bolts for easy installation and removal. $337.50 (Retail: $375) Takata 4-Point Harness (long) ![]() The 3” wide racing harness designed for mounting in a 2-seater car is the racing gear of choice when high precision driving comes first. Safety equipment comes standard with cam lock buckle device, belt length adjusters, fasteners for attachments to eye bolts and four short eye bolts for easy installation and removal. $360 (Retail: $400) Takata 5th Point Strap The 3” wide strap converts 4-Point racing harnesses to a 5-point strap configuration. Cam lock buckle provided on the 4-point racing harnesses accommodates the extra fitting. $45 (Retail: $50) Takata 6-Point Strap The 3” wide strap converts 4-Point racing harnesses to a 6-point strap configuration. Cam lock buckle provided on the 4-point racing harnesses accommodates the extra fitting. $85.50 (Retail: $95) |
| | #4 |
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Prodrive Shift Knobs ![]() These shift knobs are machined from aluminum exclusively for Prodrive, and are the perfect complement to your interior. They are designed to fit all Impreza 5 and 6-speed transmissions. They are compatible with the factory shift boot. Colors: Polished, Polished with blue top, and Black Anodized. Availability: All Subaru $59 (specify 5 or 6 speed) Prodrive Floor Mats ![]() These are Floor Mats for your Subaru Made by Prodrive. They are black and embroidered with the Prodrive Logo. They come with rings to securely mount them to the stock fasteners. These will set off the inside of your vehicle. $75/set Kartboy Knuckleball Shift Knob ![]() For the extra bit of style and performance, add a Kartboy Shift Knob to your Kartboy Shift Lever (works with the stock lever as well.) This computer designed and CNC turned Aluminum knob fits the hand with comfort, but allows a firm grip for crucial shifts. No set screws or cheezy adapter sleeves to add, it is internally threaded. For the ultimate in compatibility, a groove is included to hold up the shift boot. To top it all off, a tasteful Kartboy Shift Pattern logo is added. $40 (5-speed)/$45 (6-speed) Cobb Floor Mats ![]() Made of DuPont's RPM nylon yarn, these floor mats feature a thicker, more luxurious texture compared to the utilitarian factory mats. The design is slightly larger in some areas to provide maximum coverage and protection of your carpet. A good deal of time, dare we say R&D, went into eliminating any possible interference with pedals, trunk releases, fuel door releases, etc. The "Tractionbac" backing material will assist in preventing unwanted sliding while a reinforced floor peg hole lets you utilize the OEM floor peg to keep the driver's side mat firmly in place. Carefully matched to the factory carpet color. $95/set Last edited by GTWORX.com; 08-10-2006 at 01:22 PM. |
| | #9 | |
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
| | #14 | |
| | #15 | |
| S204 Racer Car: '04.5 STi Fav Mod: Whiteline steering rack bushings Location: Montgomery, Al Posts: 3,073
IWSTI Addict since: Apr 2006 Trader Rating: (0) | Quote:
You state the obvious so well! It's a shame your shop isn't closer to where I am. I really need to test sit some of these seats since I'm sorta kinda looking for one. This ad is not endorsed by this member. Please register or login to hide this ad. | |
