Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Dressup/Interior
Old 02-08-2010, 09:20 PM   #1
Feedback Score: 21 reviews
My StuffSubaru Parts
Fav Mod: Reliability
IWSTI Addict since: Apr 2005
Default Interior Flair LED Conversions - White/Red STi Cluster! Free Shipping!
FREE SHIPPING !!
(minimum order - $150)
VISIT OUR WEBSITE!!
Interior Flair designs and manufactures custom LED lighting conversions for Subaru owners that significantly improve the driving experience!
Email us at info@interiorflair.com for more details and quotes.
Interior Flair lighting conversions utilize the highest quality parts and techniques. Sure, there are plenty of DIY procedures out there that result in poor color and reliability, but Interior Flair provides THE professional solution! Each component is plug-n-play and utilizes factory illumination circuits and maintains dimming capability - just plug in and enjoy! We carefully engineer our lighting conversions to ensure reliability, longevity, brightness, and color match. We work diligently with each customer to arrive at the exact desired solution.
You can be confident your Interior Flair lighting solution is the highest quality available with almost 30 years of electrical engineering experience and automotive interior lighting research and development. All components are thoroughly tested prior to shipment for correct color dispersion, and absence of “hot spots”.
WRX GAUGE CLUSTER
$130
Our WRX cluster conversions come in red, blue, green, white, and other custom colors. we install additional LED lighting, remove gauge face backing, install new LCD display backlight LEDs, and place custom stage gel films to color-match. Go wild with any color scheme you can imagine!
STi GAUGE CLUSTER
$130
We are the first to offer STi gauge cluster conversions! All OEM LEDs are replaced with new and for custom colors we offer stage gel insertions as well.
MANUAL WRX CLIMATE CONTROL
$50
Incandescent stock bulb carriers are removed and red, blue, green, or white light strips installed for complete light coverage and no hot spots. Additionally, Rear Defog and AC on indicator LEDs are changed to blue, red, green, white, or custom colors.
2004 STi AUTO CLIMATE CONTROL CONVERSION - $50
Factory bulb carriers are removed and the unit is populated with super bright red, green, blue, or white LEDs. Additionally the rear defog, recirculate, and AC ON indicators are swapped to customer specified colors.
2005-2007 SUBARU CLIMATE CONTROLS
RED - $70 BLUE - $100
Factory backlight, rear defog, recirc, AC ON, and dial indicators are changed to red or blue LEDs. Gels are added behind button faces for color correction and LED currents adjusted for optimal performance and reliability. Note: Blue conversions require 2X LEDs (18 total), and additional resistors.
SUBARU DRIVER’S WINDOW PANEL CONVERSION - $30
Factory LEDs are populated to illuminate the lock and all four window switches.
PASSENGER WINDOW SWITCH CONVERSION - $25 EACH
A lens is cut and epoxied into passenger window switches to match the driver’s panel buttons. We tap into the power pins on the switch for true plug-n-play operation. The passenger window switches are a nice touch to a complete interior lighting system!
2007 HEAD UNIT LED CONVERSION - $50
Factory incandescent bulbs are replaced with LEDs.
2005-2006 SUBARU OEM HEAD UNIT LENS - $30
We have developed factory-fit red, blue and green drop-in replacement lenses for the Subaru head unit! Lenses are available for purchase or customers can send in their head unit faceplate for modification.
2005-2006 SUBARU OEM HEAD UNIT BACKLIGHT LED CONVERSION - $50
All factory incandescent bulbs are replaced with LEDs.
HEAD UNIT CONVERSIONS -Contact for quote
Yes! We convert aftermarket head units. Pricing based on required labor and parts.
02-05 SUBARU CLOCK CONVERSION - $35
The “lens cut method” is used to convert Subaru clocks to display red! The results are stunning and work well in all light conditions.
06-07 CLOCK CONVERSION - $45
OEM lens is removed and a replacement lens is bonded to the lens shell. Airbag status indicator LEDs are replaced with red (or blue) LEDs and clock and indicator currents are adjusted for optimum brightness. The results are stunning and work well in all light conditions. (note: the new lens is absent the H, M, and SET logos)
SUBARU INTERCOOLER SPRAY SWITCH CONVERSION - $25
Both JDM auto and USDM version are converted. The OEM incandescent bulbs are replaced with LED indicators, green film is removed from the switch lens, and diffused gels are used for color match and diffusion.
FOG LIGHT SWITCH CONVERSION - $25
Both backlight and “on” light sources are replaced with LED indicators. The green factory film is removed and gels are used to color match and diffuse.
SUBARU HEATED SEAT SWITCH CONVERSION - $25
The ON incandescent bulb is replaced with an LED, green lens removed, and gels are used for color matching and diffusion.
SUBARU AUX POWER/CIG LIGHTER LED MODULE -$5
2004-2005 SUBARU HEADLIGHT LEVELER - $25
Four factory green LED indicators (L0-L3) are replaced with customer color specified LED indicators. The green factory film is removed from the lens and diffused gels are placed to color match and diffuse.
2006-2007 SUBARU HEADLIGHT LEVELER - $10
Switch is disassembled and OEM LED replaced with a super bright LED.
IGNITION ILLUMINATION LED MODULE - $5
A drop-in LED replacement is provided for installation by the customer.
More photos of our work:
DEFI LINK CONVERSION - $35
Factory surface mount LEDs are replaced with super bright surface mount LEDs and we add new LEDs in locations left blank at the factory (cheap!).
NEW PRODUCT!
FOOTWELL LIGHTING KITS
$65
Interior Flair footwell lighting kits come complete with two waterproof sealed high power LED modules, a 3-position mode switch mounted into a factory switch blank, dual insulated harnesses, velcro strips, and all connectors . There are three modes; door-actuation, off, and on modes - just like the factory dome light!
The Interior Flair footwell lighting installation procedure can be found here: PROCEDURE
Prices are + return shipping. Customer is invoiced via Paypal when work is completed and shipping charges determined.
All work is covered by an unconditional 30 day workmanship warranty and a one year limited warranty. Product will be completed and shipped within 24 hours, with the exception of gauge cluster conversions. Gauge clusters require 8+ hours of labor and cannot be returned within 24 hours.
Email us with questions at:
Interior Flair is offline   Reply With Quote
Old 02-08-2010, 11:39 PM   #2
Car: CGM 2005 STi
IWSTI Addict since: Apr 2003
Default Re: Interior Lighting Conversions by Interior Flair! Free Shipping!
I have to say these guys do great work and are very easy to work with. I had all my lights done with the exception of the stereo and clock...great quality and customer service!
Ditchhanger is offline   Reply With Quote
Old 02-09-2010, 05:02 AM   #3
Car: 06 WRB STi!!!
Fav Mod: TBE!
IWSTI Addict since: Jun 2009
Will the switch for the footwell lights be a perfect fit for our blanks where the foglights are supposed to be?
highroller101 is offline   Reply With Quote
Old 02-09-2010, 05:49 AM   #4
Thanks for the props and for being our first client from Hawaii! Hang loose!
The footwell light switch comes mounted into a factory Subaru switch blank and fits perfectly! LMK if you are interested in our footwell lighting kit.
Old 02-09-2010, 07:52 AM   #5
Car: 06 WRB STi!!!
Fav Mod: TBE!
I am, i am going to order the footwell kit, cig lighter in blue.. If you have it? How hard is the havac controls to do? I want to do them in blue as well..?
Old 02-10-2010, 09:46 AM   #6
Car: 05 Aspen White STI
Fav Mod: Selling my wrx to get the sti
IWSTI Addict since: May 2009
I should be receiving my entire red light conversion kit any day now to match my sti cluster. I cant wait!
boostinbildo is offline   Reply With Quote
Old 02-18-2010, 03:24 PM   #7
Free bump for these guys, I couldnt be more happy with their work and their services!
Old 02-18-2010, 03:51 PM   #8
Feedback Score: 1 reviews
IWSTI Addict since: Oct 2004
wow, nice stuff, ill be saving up for some of these stuff for sure!
boricuajr is offline   Reply With Quote
Old 02-18-2010, 03:58 PM   #9
n00b
Feedback Score: 12 reviews
Fav Mod: GT35R
very nice stuff. all of mine came out great!!! worth the money to have it done right and reliable.
Old 02-25-2010, 04:25 PM   #10
Default Re: Interior Flair LED Conversions - Blue and Pink STi FTW! Free Shipping!
We are performing a blue STi conversion with pink accents. Here is the clock in pink:
Here is a crappy pic of the cluster. Imagine deep radiant blue and hot pink. Cleaned and painted needles, pink needle LEDs, pink blinkers, cruise, cruise set, headlights on, and shift light:
05-07 blue auto climate controls with pink ON and dial indicators:
Driver's window controls with pink door lock switch:
Thoughts and impressions welcome!
Similar Threads
The BEST Cobb AccessPORT Deals on the net!!! Plus other UNBEATABLE GR Deals In Stock! CygnusPerformance GR-Engine/ECU/Power/Drivetrain Classifieds 149 07-14-2009 05:18 PM
Free Shipping Weekend! SubaruWRXParts.com Vendor Announcements & Project Buildups 0 12-05-2008 06:33 AM
Cobb, TXS, Samco, Perrin, Blouch, DeatschWerks, AEM, K&N, Koyo, Eneos & Much More!!! OAKOSAutomotive Engine/Power/Exhaust 31 11-10-2008 11:47 AM
OAKOS Brings you Cobb, ACT, Exedy, Kartboy, and More! OAKOSAutomotive Drivetrain 8 05-27-2008 10:15 AM
Kartboy, Cobb, Perrin, Prodrive, Exedy, ACT - FREE SHIPPING on most OAKOSAutomotive Drivetrain 35 04-25-2008 07:32 AM
Privacy Policy
