| Authorized Vendor Car: 07 sti Fav Mod: chassis Location: SF Posts: 254
IWSTI Addict since: May 2008 Trader Rating: (0) | We currently have JIC Magic Full Bucket and Reclinable Racing seats in stock! Reclinable Race Seats ![]() ![]() ![]() JIC Reclinable Racing Seat is ideal for the enthusiast that seeks comfort, performance, and style for every day driving. The reclinable racing seats are wraped in an Alcantra anti-slip fabric, insulated with comfortable memory foam, and keep the driver in place with a breathable mesh down the middle of the seat. High side bolsters keep the driver in place while wide should bolsters aid the driver from excessively moving around. A strong metal skeleton keeps the seat ridgid and stable. Side knobs allow the driver to precisely adjust the seat with ease. With all these added features, JIC was still able to keep each seat under 12kg. Availble in 3 color options: Full red with red center mesh, full black with black center mesh, and black with red center mesh. A high quality embroidered 'JIC MAGIC' logo is stitched into the head of the seat to show everyone that you have one of the most unique reclinable racing seat available. Full Bucket Race Seats ![]() ![]() JIC Full Bucket Racing Seats are developed for track use with safety, support, and weight in mind. With broad shoulder support, 'blister bolsters', and a low seating position, the full bucket seats are ideal for the true motorsport enthusiast. Each seat is made with high quality cloth fabric, ultralight fiberglass shell, and soft memory foam padding. These seats weigh an astonishing, 6.4 kg! As a final touch, a high quality embroidered 'JIC Magic' logo is stitched onto the head of the seat to show that you have an exclusive JIC Magic seat. Comes in two colors, black or red. We also have Bride seats coming out of our ears! Artis 3 Artis 3 Navi Brix 2 Ergo 2 Exas 3 Gardis 3 Gias Maxis 3 Vios 3 Vios 3 Low Max Xax 2 Zeta 3 L Zeta 3 S Zeta 3 Zeta 3 Sport Gias Low MaxPM for details and pricing This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by Methodbuilt.com; 10-27-2008 at 04:30 PM. |
| | #3 |
IWSTI Addict since: May 2008 Trader Rating: (0) | Get your hands on this hot new MFD! Features include: - TFT display provides quick response with high resolution - 2 analogue and 4 digital modes, multi fuctional up to 10 gauge display options and 8 at the one time - Displays Boost, Speed, Throttle and Injector Duty - Optional Sensors allow temp and pressure readings for oil and water - Cool slim design body with large display - Simple, unique design with high quality metal plate control - Actual Size 80(L)mm x 50(H)mm x 10(W)mm ![]() ![]() ![]() ARK Design Rev-Shift Timer Comes in a compact body design (105 x 20 x 18 Milimeters) with easy settings. Has Left, Right button as well as up, down and push roller button. Features * Pro Drive Idling - 1 o Auto Mode - Calculates the engine status before post drive idling, reducing the fuel consumption by engine o Manual Mode - The post drive idle time can be manually configured by the driver * Rev Shift Timing Display - 2 o RPM is detected and shown either with an alternator pulse or from ECU Rev Signal. The lamp also flashes to remind the driver to shift up * Simple A/F o The simple AF reading is displayed through O2 Sensor Signal from the ECU. It informs the driver about the current fuel consumption o Battery Status and Charging status is displayed * Hand Brake Safety o Prevents Engine from running post drive idle mode according to hand brake status ![]() ![]() ARK Design Boost Controller Advanced Boost Controller (ABC) has a simple square body (W105 X D20 X H18 Milimeter) with easy to operate right left sew-saw switch and up down push to set roller switches, the operation has become hassle less! (Japanese utility application 506221619). The display can be seen clearly, the large high illuminated 7 segments LED changes display color according to the boost settings, at warning boost, white light flashes to ensure a comfortable drive. * Compact design : The pressure sensor is packed inside the power box to minimize the components. The compact designed control unit and solenoid valve give the option of any installation locations. * Two modes of boost pressure setting Possibility of setting A mode and B mode boost pressure * Full colour LED changes colour according to boost pressure : In addition to the large LED which changes according to the boost pressure, the colour changes when the pressure moves from negative to positive. The LED has many user definable settings including colour and scaling in the positive pressure zone * Warning display to boost pressure : Full colour LED will flash in white at the default pressure for warning. This feature can be used to visualize boost control pressure and dangerous zone. Furthermore, the warning colour can be changed to the user's preference * Safety function : When the boost is raising abnormally, it automatically off the control and switch to normal control. * Peak hold display : The peak of boost pressure is memorized. ![]() PM for price, available now! Last edited by Methodbuilt.com; 08-22-2008 at 11:22 AM. |
| | #13 |
IWSTI Addict since: May 2008 Trader Rating: (0) | Unfortunately, we dont think so. we are going to try and hook up a wideband O2, and see if it works |
| | #15 |
IWSTI Addict since: May 2008 Trader Rating: (0) | PMs answered This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
