Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Dressup/Interior
Old 05-13-2008, 03:26 PM   #1
Car: '93 L & '06 STi
Default DEFI Racer Gauges! Available in blue, red or white! No Control Unit Needed!
Been wanting the quality of Defi gauges but without the high cost so just settling for knock off gauges that end up not reading correctly? Well NO MORE! Racer Gauges are quick-responsive and high-accurate analog gauges. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. Defi has added the colors white and red to their Blue Racer Gauge collection. These gauges are available only in 52mm, features bright LEDs, opening and closing ceremonies, full 270 degrees sweep dial provides ultimate visibility, mounting bracket & instrument case, red triangle of the regular position bezel can be used as a warning indicator and Does NOT require the Defi-Link Control Unit for use.
Ignition off:
Blue:
Red:
White:
Opening Ceremony:
Ending Ceremony:
PM for Pricing!
Thanks,
Greg
GST Motorsports is offline   Reply With Quote
Old 05-13-2008, 04:43 PM   #2
Car: 05 Aspen White STi
Fav Mod: 04 WRX -> 05 STi
Default Re: DEFI Racer Gauges! Available in blue, red or white! No Control Unit Needed!
PM price for boost, egt, oil pressure in imperial units. Do you have the triple hood pod also?
Jelphree is offline   Reply With Quote
Old 05-14-2008, 11:28 AM   #3
PM sent.
Thanks,
Greg
Old 05-27-2008, 08:53 PM   #4
Fav Mod: Access Port V2
boost, egt, oil pressure and hood pod?? how much
St-ill is offline   Reply With Quote
Old 05-28-2008, 02:44 PM   #5
PM sent.
Thanks,
Greg
Old 06-25-2008, 10:33 AM   #6
Bump!
