Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Dressup/Interior
Closed Thread
Old 04-15-2008, 03:35 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Electronic Blowout-Defi-Blitz-STRI Gauge Combos-From $500- Sun Auto Hyper Ground$129
Great electronic sales this week guys. Now available the entire Cyber Speed line! Best prices anywhere. Dont forget to check out the AIM Sports Gaugle cluster. This thing is awesome! We actually used this on our new 350z We compete with in Formula D!
AIM Sports XML Gauge Cluster
-1 AMP + 2 binder connectors
-Lap Times & Split Lap Times
-RPM - numerical and graphical display tach
-Max RPM stored for later recall
-Total Run Time
-Gear Position
-Total and partial odometer
-8 analog sensor inputs for temperature, pressure, lambda sond, potentiometers, etc.
-1 wheel speed input.
-128 kb of non-volatile memory.
-Brilliant blue display with backlight.
-6 fully configurable alarm LEDs.
-10 fully configurable shift LEDs.
-Requires 8-15V power from vehicle. Auto Power OFF feature.
-Weight: 21.2 oz (600 grams)
-Size: 6.9"x4.3"x1"
$1099 Shipped
Defi Gauges
The BF Series has a unique "masked" look that hides the gauge face until the car is started. Then you are treated with startup and shutdown sequences. These gauges are manufactured using the special manufacturing process used to by Defi's parent company to make many OEM gauge clusters such as for the STI. Defi BF Package 60mm(Black/White)
-Defi V2 Control Unit
-Boost + EGT + WT or OT
-ATI Triple Gauge Pod
$799 Shipped
Defi BF-R Package 60mm(Black/Red)
$799 Shipped
Blitz MD (Mirror Drive)
Identified by its "Mirror Face", the MD (Mirror Drive) Racing Meter features a carbon or white face and brushed aluminum bezel. The face of the gauge is back-lit with LED light bulbs and the needle is lit red. When the gague is off, the face disappears and your reflection can be seen, hence the name Mirror Drive. The MD Racing Meters are full electric gauges and are available in boost, oil/water temperature, oil/water pressure, and exhaust temperature. (Available only in 60mm, all gauges include necessary hardware and sensors.)
Blitz MD Gauge Package 60mm (Black/Red)
-Blitz MD Electronic Boost
-Blitz MD Electronic Water Temp
-Blitz MD Electronic Oil Temp
$699 Free Shipping
Greddy V-Manage
The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response.
04-06 STI AVCS ENGINES ONLY
$475 Shipped
Cobb Accesport
The AccessPORT reprograms your vehicle's computer to optimize the air/fuel ratio and ignition timing, increase boost, remove the speed limiter, and more for performance results you can instantly feel!
PM Best Price Anywhere
Apexi Super Grounding System
Developed using innovative new concepts, the new A'PEX Super Grounding System stabilizes electrical noise and voltage spikes. The Super Ground System maximizes electrical component efficiency by combining an electrical grounding system with a battery current and voltage stabilization control unit. The control unit features an electrical charging system and electrical noise filter. The double noise filter smoothes turbulent electrical current, providing a stable and consistent voltage flow to all your vehicles electrical devices. The A'PEX Super Grounding System maximizes the efficiency of all factory vehicle electrical systems, allowing smoother engine operation, more efficient electrical component operation, and improved electrical current. The stylish voltage stabilizer box compliments any engine bay with its attractive case design and ominous backlit A'PEX logo.
- Uses a high capacity Double Condenser and Double Noise Filter
- The A'PEX Super Ground System uses a high purity, temperature resistant OFC cable (non-oxidized copper) Copper wire diameter: 0.12mm X 665 utilizes inter-twined wire
$175 Shipped
HKS Circle Earth Grounding System
Circular Grounding System - By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points. Each 8 gauge spiral twined cable is wrapped with signature HKS purple plastic to protect and add color to the Circle Earth System. Vehicle specific kits included pre-measured cable lengths and distribution blocks.
$115 Shipped
Cyber Speed Hyper Ground System
The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation.
$129 Shipped
Cyber Speed Hyper Force System
The Hyper Force system is the next gernation high-efficiency ignition tuning and strengthening system. It works by absorbing all back electromovtive force, which aids to improve plug voltage and promote complete combustion by producting 100$ coil efficiency. Also, the hyper Force System eliminates any ignition performance loss due to descreased electrical current under heavy throttle. Since ignition efficiency over the entire revolution range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emission.
Hyper Force W/ Harness
$325 Shipped
Cyber Speed Hyper Voltage System
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
$225 Shipped
Gruppe-S is offline
Old 04-16-2008, 10:09 AM   #2
Trader Rating: (13)
Default Re: Electronic Blowout-Defi-Blitz-STRI Gauge Combos-From $500- Sun Auto Hyper Ground$
Gruppe-S is offline
Old 04-17-2008, 10:40 AM   #3
Trader Rating: (13)
Gruppe-S is offline
Old 04-21-2008, 11:01 AM   #4
Trader Rating: (13)
Gruppe-S is offline
Old 04-22-2008, 11:09 AM   #5
Trader Rating: (13)
Gruppe-S is offline
Old 04-23-2008, 11:41 AM   #6
Trader Rating: (13)
Gruppe-S is offline
Old 04-24-2008, 11:11 AM   #7
Trader Rating: (13)
Gruppe-S is offline
Old 04-25-2008, 10:00 AM   #8
Trader Rating: (13)
Gruppe-S is offline
Old 04-28-2008, 11:40 AM   #9
Trader Rating: (13)
Gruppe-S is offline
Old 04-29-2008, 11:28 AM   #10
Trader Rating: (13)
Gruppe-S is offline
Old 04-30-2008, 10:16 AM   #11
Trader Rating: (13)
Gruppe-S is offline
Old 05-01-2008, 09:48 AM   #12
Trader Rating: (13)
Gruppe-S is offline
Old 05-01-2008, 09:58 AM   #13
Trader Rating: (13)
Gruppe-S is offline
Old 05-02-2008, 09:39 AM   #14
Trader Rating: (13)
Gruppe-S is offline
Old 05-06-2008, 12:03 PM   #15
Trader Rating: (13)
Gruppe-S is offline
Closed Thread
