Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Dressup/Interior
Closed Thread
Old 01-07-2008, 05:09 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Electronic Blowout-Defi-Blitz-STRI Gauge Combos-From $500- Sun Auto Hyper Ground$99
We got some great stuff for you guys this time. Defi gauges in stock ready to ship. Also now available is the Sun Auto Hyper Ground and Hyper Voltage in stock ready to ship. Also all digital boost controllers on sale.
Defi Gauges
The BF Series has a unique "masked" look that hides the gauge face until the car is started. Then you are treated with startup and shutdown sequences. These gauges are manufactured using the special manufacturing process used to by Defi's parent company to make many OEM gauge clusters such as for the STI.
Defi BF Package 60mm(Black/White)
-Defi V2 Control Unit
-Boost + EGT + WT or OT
-ATI Triple Gauge Pod
$799 Shipped
Defi BF-R Package 60mm(Black/Red)
$799 Shipped
Blitz MD (Mirror Drive)
Identified by its "Mirror Face", the MD (Mirror Drive) Racing Meter features a carbon or white face and brushed aluminum bezel. The face of the gauge is back-lit with LED light bulbs and the needle is lit red. When the gague is off, the face disappears and your reflection can be seen, hence the name Mirror Drive. The MD Racing Meters are full electric gauges and are available in boost, oil/water temperature, oil/water pressure, and exhaust temperature. (Available only in 60mm, all gauges include necessary hardware and sensors.)
Blitz MD Gauge Package 60mm (Black/Red)
-Blitz MD Electronic Boost
-Blitz MD Electronic Water Temp
-Blitz MD Electronic Oil Temp
$699 Free Shipping
STRI Gauges
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
STRI Gauge Package 52mm (Black/Red)
-Boost
-Water Temp
-Oil Temp
$500 Free Shipping
Digital Boost Controllers
Apexi AVCR
$375 Shipped
HKS EVC 6
$550 Shipped
Blitz SBC I Color
$709 Shipped
Greddy Profec E-01
$535 Shipped
Greddy V-Manage
The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response.
04-06 STI AVCS ENGINES ONLY
$475 Shipped
HKS A/F Knock Amp
The HKS A/F Knock Amp is an electronic monitoring device that displays two of the most vital engine conditions for tuning; engine knock and air/fuel ratio. Engine knock occurs when there is abnormal combustion knock as detonation; which can rob power, reduce engine longevity and even lead to catastrophic failure
$699 Shipped
Sun Auto
The new Hyper Ground System is the safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more Torque,better Mileage, better Response, and better Starting Ability.
Hyper Ground
$99 Shipped
Hyper Voltage GT
$199 Shipped
Apexi Super Grounding System
Developed using innovative new concepts, the new A'PEX Super Grounding System stabilizes electrical noise and voltage spikes. The Super Ground System maximizes electrical component efficiency by combining an electrical grounding system with a battery current and voltage stabilization control unit. The control unit features an electrical charging system and electrical noise filter. The double noise filter smoothes turbulent electrical current, providing a stable and consistent voltage flow to all your vehicles electrical devices. The A'PEX Super Grounding System maximizes the efficiency of all factory vehicle electrical systems, allowing smoother engine operation, more efficient electrical component operation, and improved electrical current. The stylish voltage stabilizer box compliments any engine bay with its attractive case design and ominous backlit A'PEX logo.
- Uses a high capacity Double Condenser and Double Noise Filter
- The A'PEX Super Ground System uses a high purity, temperature resistant OFC cable (non-oxidized copper) Copper wire diameter: 0.12mm X 665 utilizes inter-twined wire
$175 Shipped
HKS Circle Earth Grounding System
Circular Grounding System - By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points. Each 8 gauge spiral twined cable is wrapped with signature HKS purple plastic to protect and add color to the Circle Earth System. Vehicle specific kits included pre-measured cable lengths and distribution blocks.
$115 Shipped
Helix Super Ground Kit
Helix uses a loop system. Meaning it starts at the negative terminal and goes from one spot to the next in series. Connecting to all major conducting pieces of the car, IE: throttle body, engine block, firewall, fender, transmission, and such. The Helix Ground Kit uses a TRUE 4 Gauge wire where others use a smaller 8 guage. Helix Ground Kit are oxygen free meaning perfect electrical current.
$59 Shipped
CLICK HERE FOR ELECTRONIC SPECIALS -- UPDATED DAILY
Call in to order!
We accept Visa, Mastercard, and paypal.
GRUPPE-S, please specify vehicle, part, and your info.
Thanks,
Gruppe-S Sales
GRUPPE-S
20521 Teresita Way
Lake Forest, CA 92630
949-457-1234 x 2
Gruppe-S is offline
Old 01-08-2008, 09:54 AM   #2
Trader Rating: (13)
Default Re: Electronic Blowout-Defi-Blitz-STRI Gauge Combos-From $500- Sun Auto Hyper Ground$
Now Available. MXL race data acquisition systems. Plug and play systems thru your OBD2 Port. Uses stock sensors for easy installation.
The MXL are powerful race data acquisition systems, used by automotive racers around the world. Powerful enough for world class GT cup cars and LeMans racers, yet easy to own and install. The MXL is the racing data aquisition system of choice for amateur and semi-pro SCCA and NASA club racers.
-1 AMP + 2 binder connectors
-Lap Times & Split Lap Times
-RPM - numerical and graphical display tach
-Max RPM stored for later recall
-Total Run Time
-Gear Position
-Total and partial odometer
-8 analog sensor inputs for temperature, pressure, lambda sond, potentiometers, etc.
-1 wheel speed input.
-128 kb of non-volatile memory.
-Brilliant blue display with backlight.
-6 fully configurable alarm LEDs.
-10 fully configurable shift LEDs.
-Requires 8-15V power from vehicle. Auto Power OFF feature.
-Weight: 21.2 oz (600 grams)
-Size: 6.9"x4.3"x1"
$1099 Shipped
Gruppe-S is offline
Old 01-10-2008, 05:12 PM   #3
Trader Rating: (13)
Bump guys
Gruppe-S is offline
Old 01-11-2008, 11:18 AM   #4
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-14-2008, 12:25 PM   #5
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-14-2008, 08:45 PM   #6
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
Bump for you.
boostedrex05 is offline
Old 01-15-2008, 09:51 AM   #7
Trader Rating: (13)
Bump guys
Gruppe-S is offline
Old 01-16-2008, 10:01 AM   #8
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-17-2008, 11:24 AM   #9
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-18-2008, 01:50 PM   #10
Trader Rating: (13)
Bump guys
Gruppe-S is offline
Old 01-21-2008, 02:05 PM   #11
Trader Rating: (13)
Bump guys
Gruppe-S is offline
Old 01-22-2008, 09:39 AM   #12
Trader Rating: (13)
Bumnp guys
Gruppe-S is offline
Old 01-23-2008, 10:03 AM   #13
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-24-2008, 09:44 AM   #14
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Old 01-25-2008, 10:53 AM   #15
Trader Rating: (13)
Bump Guys
Gruppe-S is offline
Closed Thread
