Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Dressup/Interior
Closed Thread
Old 12-10-2007, 05:47 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default Stocking Stuffer Specials! COME IN AND SEE! Best Gift for friends or your Subaru!
We are offering a Christmas special on behalf with Cobb tuning
FREE SHIPPING WITH PURCHASE OF 2 ITEMS LISTED BELOW!
Cobb Tuning Oil Filler Cap
50.00
Introducing the CAD Designed and CNC machined Billet Aluminum COBB Oil Filler Cap. Complete with the COBB logo engraved predominately on top, "Knurling" style cut on the sides for added grip and a Subaru factory o-ring to ensure a proper seal. The perfect finishing touch on any COBB tuned Subaru engine compartment. Available in an Anodized Gold or Blue for a long lasting finish. Direct replacement for the factory oil cap.
Cobb Tuning Battery Tie Down
COBB is proud to announce the new COBB Billet Battery Tie Down for all late-model Subarus.
CAD designed and CNC machined from billet 6061-T6 and hard anodized for a long lasting finish. Directly replaces the factory battery tie down. Guaranteed to make your battery...well, better looking.
Cobb Double Adjustable Shifter 135.00(except Legacy Spec B, 165.00)
Our revolutionary Double Adjustable Shifter ushers in a new generation of adjustability for one of the most critical links from driver to car with the ability to control both the height of the shifter as well as the throw.
Designed using CAD technology, the COBB Blue anodized billet shifter body is CNC machined from 6061 Aluminum. Like our original design, the shift throw distance and shift knob height are independently adjustable and both can easily be adjusted with the shifter installed in the vehicle. Stainless Steel socket head screws are set in a counter bore for a flush mount and provide a clamping force that firmly holds the upper and lower slider shafts in place. This new design improves the ease of making adjustments while also being significantly stronger.
Compatible with the factory shift knob or any aftermarket knobs designed to replace the factory unit
Cobb Six Speed Shifter Bushings 35.00
Cobb 5-Speed Shifter Bushings 30.00
Cobb Tuning STI Turbo Heat Shield 50.00
Cobb Tuning LGT / Outback XT Turbo Heat Shield 50.00
Cobb Tuning WRX ForesterXT Turbo Heat Shield 50.00
Cobb Tuning 04-05 WRX / STI Radiator Shroud 65.00
The COBB Tuning Radiator Shroud is designed to focus air through the radiator, which in turn, will lower the engine operating temperature.
While driving, air traveling through the grill can sometimes escape around the top between the frame and the radiator. The COBB radiator shroud directs the maximum amount of air to where its needed most. Not only does the COBB Radiator Shroud save weight over other radiator shrouds by being made of aluminum, it also eliminates the need to use the OEM radiator support brackets. This attention to detail lends to a very clean underhood look!
Please Call in to place order.
801-748-4910 ext 1006
Thanks
Kirill
RallySportDirect.com
RallySportDirect is offline
Closed Thread
