Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Dressup/Interior
Old 11-01-2007, 06:27 PM   #1
Car: Family, Car.
Fav Mod: Anything MadDad
Default STi 60mm Gauges - Wireless Remote
Most of you folks have probably already seen the info on MadDad Ultra Series gauges in the 5 months we've been running the pre-order Group Buy discounts while waiting for them to be delivered. Well the wait is finally over and it's not too late to take advantage of the origonal GB discounts that will run through November 16th. If you haven't read the spec sheet on the Ultra series here is a run down:
* Modeled to be the closest STi cluster look gauge offered by any brand right down to the font style and color match. This is what Subaru should be selling you.
* No brand logos cutting across the gauge face. We keep it clean to reinforce that OEM look. These gauges look like they belong in the car.
* IR Wireless Remote controls all gauge functions - No need for separate control boxes despite full array of functions the gauges offer.
* No buttons on the gauge face giving you a very clean uncluttered look(thanks again to the wireless remote)
* Adjustable Warning Points
* Peak Recall and Reset
* Independant warning and peak indicator lamps
* Calibration Port for Boost gauge. Yes, if you live in Colorado or places with large elevation/atmospheric pressure differences or even minor tolerence differences with sending units you can press a button and your gauge will recalibrate itself to 0 psi. Never have a boost gauge that doesn't say 0 psi ever again.
* 50 second record, playback(with pause/play option)
* External Warning Lamp port - every gauge can also run a separate larger warning lamp(shift light type) available in Blue or Red.
* Audible Alerts - can be turned on/off
* Auxilury Device Support - Gauges can interface with additional Add-On devices that make use of the gauge face as the interface, eliminating the need for addtional control boxes to mounted in your cabin.
* Turbo Timer, add-on for Boost gauge that gives Turbo Timer function set through the face of the boost gauge(in device mode you use the boost gauge to set the run time of the turbo timer)
* Raditor Fan Controller - Add-on for the water temp gauges allows triggering radiator fan tied to water temp warning.
* Contrast Dims when headlights are turned on
* STi black-out when shut off - very light silhouette of the gauge face is visible very similiar to the STi cluster.
* Power on needle sweep/inspection, similiar to STi. Single needle sweep with just the needle light up. When the sweep is done the gauge backlighting turns on.
* Power off needle sequence(bling only)
* Flagship quality components. Gorgeous brushed aluminum casings you almost don't want to hide in a pod. Top quality sending units thoughout. Oil Pressure sending unit is super small to fit galley plug location without any clearance issues. Pre-tapped 1/8" NPT galley plug included with oil pressure and oil temp. Even the small details are here such as gauge wiring that is aluminum shielded. Gauges support daisy-chaining 3 at a time for common wiring. All sensors wires are extra long so you won't have to crimp any extra wire. Ever sensor uses lock connectors, you won't crimp a single wire. Wireless remote will command upto 10 different gauges.
Currently we have IN STOCK. Boost, EGT, Oil Pressure, Oil Temp. Due in about 45 days. Fuel Pressure, Water Temp, Voltage....shortly after Wideband A/F, and shortly after(first time announceing) G-Meter Performance meter, all matched to the look you see below.
So what to they cost and what to they look like:
Standard individual gauges prices range from $144.95 to $249.95 (without remote). Standard remote cost is $34.95
The GB that is running through Oct 16 allows you to pick any 3 gauges for $449.95 plus shipping($10 or less in most cases). All 3 or more purchases will get the wireless remote for FREE.
Direct Buy Link
External Warning Lamps are $24.95.(2 for 39.95, 3 for $49.95) These are great quality lamps in aluminum housings to dissipate heat, not plastic. Available in Red or Blue.
Turbo Timer Add on for boost gauge is just $24.95 during the GB. That's right, a turbo timer for $24.95 and you don't have to mount any control box anywhere either. Boolya !!
daddysscp is offline   Reply With Quote
Old 11-01-2007, 06:29 PM   #2
Car: Family, Car.
Default Re: STi 60mm Gauges - Wireless Remote
You also get a 60mm universal base/mount..not shown in the photos.
Boost
EGT
Oil Pressure
Old 11-01-2007, 06:41 PM   #3
Car: Family, Car.
Video example. How to set warning points on your MadDad(TM) Ultra Series gauges with the wireless remote.
YouTube Link
Old 01-31-2008, 04:27 PM   #4
Car: Family, Car.
After being out of stock on boost gauges for the past 5 weeks we finally have everything back in stock. We also received the water temp and volt meter in the Ultra series. So in stock ready to ship is : Boost, EGT, Oil Pressure, Oil Temp, Water Temp, and Volt. We are going to be updating pricing on these for 3 gauge bundles. Depending on the 3 gauge combo you will actually be able to get into a 3 gauge setup for as low as $363 if you choose the lower cost gauges e.g. Boost, Oil Temp, Volt or Boost, Oil Temp, Water Temp. Basically any combination of Boost, Water Temp, Oil Temp and Volt will end up $363 and some pennies..assuming a boost gauge is one of the 3. If you are getting Boost, EGT, Oil Pressure those are the 3 most expensive gauges and those will run you $521. We've been at the pre-order $449.95 pricing on that popular combo for quite some time now. Even at $521 these gauge have no equal in the market. If those are your 3 gauges of choice order right now before I update the website to the new pricing structure. If your looking for basic gauges you can go elsewhere for less. If you want every bell and whistle in the book and then some, this is it. Go back to the first thread for the laundry list - the list is quite insane. There is no equal to a set of Ultra's.
R.
Old 01-31-2008, 08:09 PM   #5
Car: 06 Subaru WRX STi OB
Fav Mod: Upgrading 04 WRX Wagon to 06 STi
Hey Rich, I sent you a PM on the 15th about my remote, but never heard back from you. Any word?
god5337 is offline   Reply With Quote
Old 02-01-2008, 05:12 AM   #6
Car: Family, Car.
Sorry about that I forgot to PM you back. I went to box a replacement and was out of stock. I did get more in with the order we just got so thanks for the reminder. I'll float you a PM as soon as it's out the door(later today).
R.
Old 02-13-2008, 06:49 PM   #7
Fav Mod: Boost gauge
R.
Still waiting for you guys to update the site so I can buy my (cheap) three gauge pack.
Old 02-13-2008, 07:47 PM   #8
Car: 06 white STi
Fav Mod: Prodrive CAI, REAL V-Limited Lip
Boost, EGT, and Oil Pressure in stock?
Impretzle is offline   Reply With Quote
Old 02-13-2008, 08:36 PM   #9
Well, I have still not gotten anything from you, not even the PM. I imagine you are busy, but it has been a long time and i can not get the full use of my gauges without the remote, much less tell if they are bad or not. Please update.
R.
Old 02-14-2008, 08:05 AM   #10
Car: 06 white STi
well, i just placed an order for boost,egt,and oil press
Old 02-14-2008, 08:42 AM   #11
Fav Mod: buying a sti and gias
rich is on vacation until the 18th
jmanrex is offline   Reply With Quote
Old 02-16-2008, 05:06 PM   #12
Fav Mod: tein
hey man, please get back to me when you return from vacation. I still would like to get the gauge pack i pre-ordered in august! thanks-
blustile2240 is offline   Reply With Quote
Old 02-20-2008, 09:33 PM   #13
Car: 06 white STi
any word on when my order will be shipped out?
i ordered the 3 gauge bundle + pod + turbo timer on feb 2nd
I understand you were on vacation until monday, just give me some updates please
thanks
-cameron
Old 02-21-2008, 07:08 AM   #14
Car: Family, Car.
cameron - left you a vm earlier this morning, we're out of oil pressure which is why it wasn't processed yet. We can talk about options.
Impretzle - Buzz me today, I'm in the office: 978-401-4624. Will PM you as well. We tried to process your order way back in October...CC was declined. We sent a notification, maybe ended up in the spam folder .
Just left you a vm as well.
R.
