| Authorized Vendor
Car: 05 PSM Stage 4 Fav Mod: Pro-Tune Location: Big D Posts: 1,804
IWSTI Addict since: Apr 2005 Trader Rating: (17) | FREE SHIPPING ON ORDERS OVER $200!! We were the first vendor to offer complete interior lighting conversion to the Subaru community! Email us at info@interiorflaire.com for more details and quotes. INTERIOR LIGHTING CONVERSIONS Interior Flaire! lighting conversions use only the highest quality parts and techniques. Each solution is completely plug-n-play-just plug in and enjoy! Each solution is carefully engineered to ensure reliability, longevity, correct brightness, and color match. We work diligently with each customer to arrive at the exact desired solution. You can be confident your Interior Flaire! lighting solution is the highest quality available with almost 30 years of electrical engineering experience and research and development on automotive interior lighting. All parts are tested electrically, for correct color dispersion, and absence of “hot spots”. WRX GAUGE CLUSTER $125 Our WRX cluster conversions come in red, blue, green, white, and other custom colors. we install additional LED lighting, remove gauge face backing, install new LCD display backlight LEDs, and place custom stage gel films to color-match. Go wild with any color scheme you can imagine! STi GAUGE CLUSTER $150 We are the first to offer STi gauge cluster conversions! All OEM LEDs are replaced with new and for custom colors we offer stage gel insertions as well. 2002-2004 SUBARU WRX HVAC $40 OEM incandescent bulb carriers are converted to either a red, blue, white, or green LED carrier. For the do-it-yourselfer, new converted bulb carriers are available for $20 each. 2004 SUBARU STi HVAC $50 OEM incandescent bulb carriers are converted to a red, blue, white, or green LED carrier and control LED indicators are changed to matching colors. 2005-2007 SUBARU RED HVAC $40 BLUE $75 OEM surface mount LED backlight, rear defog, recirc, and AC “on” indicators, and current setting resistors are changed to super bright red OEM fit surface mount components. SUBARU DRIVER’S WINDOW CONTROLS $25 Subaru Impreza driver’s window controls come from the factory with only the driver’s window and lock button illuminated. This is lame! However, the panel is equipped to illuminate all but the passenger lock-out switch. We install super bright surface mount LED indicators on the switch panel circuit board that illuminate all window switches and the door lock button the way it should be! SUBARU PASSENGER WINDOW CONTROLS $25 each A custom fabricated lens is cut into passenger window switches to match the driver’s panel buttons. We tap into the power pins on the switch for true plug-n-play operation. The passenger window switches are a nice touch to a complete interior lighting system! 2007 SUBARU OEM HEAD UNIT CONVERSION $35 Factory bulb covers are replaced with aftermarket covers. Conversion includes LCD display. 2005-2006 SUBARU OEM HEAD UNIT LENS $30 We have developed a stunning red, drop-in replacement lens for the OEM head unit! Lenses are available for purchase or customers can send in their head units for us to modify. (NOTE: HU backlight is additional $10) NON-OEM HEAD UNIT CONVERSIONS $25/HR Yes! We convert aftermarket head units. Price is based on time required for each unit. 02-05 SUBARU CLOCK CONVERSION $30 The “lens cut method” is used to convert Subaru clocks to display red! The results are stunning and work well in all light conditions. 06-07 SUBARU CLOCK CONVERSION $45 We repmove the OEM lens face and bond a custom aftermarket lens. Then we replace the airbag indicator LEDs with super bright white LEDs. The results are stunning and work well in all light conditions. (note: the new lens is absent the H, M, and SET logos) SUBARU INTERCOOLER SPRAY SWITCH $20 Both auto and USDM version are converted. The OEM incandescent bulbs are replaced with LED indicators, green film is removed from the switch lens, and diffused gels are used for color match and diffusion. Note: USDM Subaru factory wiring does not facilitate illumination of the “arm” indicator on JDM auto intercooler switches. Therefore, “arm” incandescent indicators are not modified unless specified by customer. SUBARU FOG SWITCH $25 Both backlight and “on” light sources are replaced with LED indicators. The green factory film is removed and gels are used to color match and diffuse. SUBARU HEATED SEAT SWITCH $25 each "ON” incandescent bulb is replaced with an LED. The green factory film is removed and gels are used to color match and diffuse. SUBARU AUX POWER/CIG LIGHTER PORT $15 Customers send factory power/light harness and we replace the OEM incandescent bulb with a frosted LED. The results are a deep blood red. Sinster! 2004-2005 SUBARU HEADLIGHT LEVELER $20 Four factory green LED indicators (L0-L3) are replaced with customer color specified LED indicators. The green factory film is removed from the lens and diffused gels are placed to color match and diffuse. 2006-2007 SUBARU HEADLIGHT LEVELER $10 Switch is disassembled and the OEM LED is replaced with a super bright LED. BULB COVERS FOR SUBARU KEY RING MOD $5 2 bulb covers and key ring mod instructions are shipped with each interior conversion package. More photos of our work: We did this gauge cluster in blue: DEFI CONTROL UNITS $30 The factory surface mount LEDs are replaced with super bright surface mount LEDs and we add new LEDs in locations left blank at the factory (cheap!). Prices do not include return shipping. Customer is invoiced via Paypal when work is completed and shipping charges determined. Key ring conversion instructions are included with all return shipments. All work is covered by an unconditional 30 day workmanship warranty and a one year limited warranty. Product will be completed and shipped within 24 hours, with the exception of gauge cluster conversions. Gauge clusters require 8+ hours of labor and cannot be returned within 24 hours. Email us with questions at: info@interiorflaire.com Cory Brown Interior Flaire! This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by Interior Flaire; 01-05-2009 at 07:09 PM. |
| | #3 |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | Please feel free to contact us with any questions you may have about this service. Some of the details about what we do with buttons:
CB |
| | #4 |
| Grassroots STI Racer
Car: 04 wrb sti Fav Mod: buying a sti and gias Location: enola, pa Posts: 523
IWSTI Addict since: Feb 2004 Trader Rating: (6) | hey cory, can you do all the passenger window controls front and rear or just front?? |
| | #7 | |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | Quote:
We actually DO cut a lense into the window controls, however, and form an epoxy lense to match the drivers controls. There is 12V available at the switch when the ignition is on and we tap into this source. The switch is still completely plug-n-play! CB Interior Flaire! | |
| | #8 |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | |
| | #9 | |
IWSTI Addict since: Feb 2004 Trader Rating: (6) | Quote:
i might be sending them out over thanksgiving--can you please pm your address again--i don't think i still have it from all the other things you turned red for me free bump--great work especially with turning the bulbs in my hvac into led's thanks | |
| | #10 |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | I converted my clock to red this week! I am having some lenses made. The method will be the "cut the center out of the existing lense" style but with extreme high quality that will look completely factory. I am also having some red OEM (05-06) head unit lenses made. Very soon we will have the total package! Anybody interested in converting their clock and Head Unit? CB |
| | #11 |
| Professional STI Driver Car: Silver 05 WRX STi Fav Mod: Advan RGIIs Location: Bloomington IL Posts: 443
IWSTI Addict since: Apr 2004 Trader Rating: (2) | Interested if you can convert the head unit. Don't have a clock so don't care too much about that... PM was sent with some questions. Thanks, Mike |
| | #12 |
| Professional STI Racer Car: 07 Impreza WRX STI, Fav Mod: Track days!!! Location: Chino Ca Posts: 621
IWSTI Addict since: Mar 2007 Trader Rating: (0) | Hey can you pm me a price shiped to 91710 on the hole kit for a 07 Sti. Thanks a bunch. Matt C. |
| | #13 |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | Bump it up for more pics in post #1 and edited details! CB |
| | #14 |
| Authorized Vendor
IWSTI Addict since: Apr 2005 Trader Rating: (17) | CB Interior Flaire! |
| | #15 | |
| Junior STI Driver Car: '07 Aspen White STI Fav Mod: Mod this! Location: Miami, Fl Posts: 106
IWSTI Addict since: Nov 2007 Trader Rating: (1) | Quote:
I would love to do this (maybe everything but the clock) but I am from Miami.....is there any way you sell some sort of kit that i can purchase and have installed somewhere over here or you only do custom work.... sorry if its a dumb question i was just having some trouble understanding the purchasing process??? This ad is not endorsed by this member. Please register or login to hide this ad. | |
| Thread Tools | |
