Clutch delay valve repost (with pics) - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > > > Clutch delay valve repost (with pics)
Old 08-17-04, 02:35 PM   #1
sanhedrin
Contributor
sanhedrin is an unknown quantity at this point
Exclamation Clutch delay valve repost (with pics)
Just got the pics, and thought I'd repost the writeup with the pictures. (Click the pics for bigger ones)
This is in reference to this thread:
http://www.imprezawrxsti.com/postnuk...wtopic&t=11904
Materials needed
1- m16x1.5x20mm bolt
2- 15mm in diameter washers (check this diameter the washers should fit
inside mastercylinder they should be 1/2 I believe)
brake fluid
1.) remove the safety clip from clutch actuating arm between accelerator
pedal and the tranny tunnel.
2.) remove pin from clutch actuating arm, it has a safety on it so you have
to use a needle nose and squeeze the end and pull it half way out. Then
push arm to the other direction to butt it up to the other side of the of
the master cylinder actuating arm. If you get the pin stuck inside push it
back in and start over again. This will make more sense when you look at
it.
3.) remove intercooler.
4.) remove starter.
5.) remove bolts for slave cylinder.
6.) remove bolt holding the line to the pitch link mount on fire wall.
7.) remove nuts off of the master cylinder mount on the fire wall.
8.) remove Hydraulic clutch system from car
system removed from car.
remove these fasteners.
It should look like this.
remove shim housing from Slave.
remove shim housing from Master.
What remains.
locate Fellel fitting inside Slave cylinder
Find an appropriate diameter wood screw to thread tightly into Ferrel
insert. Then with the Slave held firmly in a vise take the claw of one
hammer and hold the screw like you would to pull out a nail. With another
hammer hit the claw till the ferrel is removed. (note: not much force is
needed)
This is what you should have once the Ferrel is removed
Next is the master cylinder.
Parts needed to plug hole in master. (note: you must file the end of the
bolt to a flat surface to insure a good seal with copper washers)
Insert washers as shown.
Thread bolt into Master Cylinder and tighten till it bottoms out on
washers. Then add 1/8 turn to compress washers.
Reinstall lines to Master Cylinder and Slave Cylinder. (note: the bend in
the line must go towards the body of the Slave Cylinder.)
Please note angle of the line relative to the Slave Cylinder for proper
fitment. Now tighten all fittings (snug + 1/8 turn)
what's left
bench bleed system and reinstall in reverse order to 1-8 as listed above.
sanhedrin is offline
Old 08-17-04, 02:44 PM   #2
salaki
Advanced Contributor Level 4
Feedback Score: 1 reviews
Car: WRB STi - WRR 92X
salaki is an unknown quantity at this point
Courtesy of BikerBoy
Good mods.. Tried this on 2G DSM and I liked it so much and very soon will do it on my STi.
Moderator.. Please make this sticky so I don't loose this again..
SUBBIE: Subaru Tecnica International - Impreza WRX STi - World Rally Blue
SALAKI: Saabaru Tecnica International - 92X Aero - World Rally Red
salaki is offline
Old 08-17-04, 03:43 PM   #3
HiRevImports
Feedback Score: -1 reviews
HiRevImports is an unknown quantity at this point
Default Many Stock STi Parts F/S!!
Thanks for the pics. Does anyone actually have any first hand experience with this mod on an STi??
Chris Wirkus
Hi Rev Imports
chris@hirevimports.com
http://www.hirevimports.com
P: 631-791-4015 AIM: hirevimports
HiRevImports is offline
Old 08-17-04, 03:45 PM   #4
salaki
Soon..
I am having trouble finding the bolt..
Local hardware store don't carry it..
Any advice?
I did this type of mod on my 2G DSM Eclipse before and the clutch engaged a LOTTTTT faster..
salaki is offline
Old 08-17-04, 06:49 PM   #5
Digitalfiend
Car: 08 DGM STI
Fav Mod: My wife :)
Digitalfiend has a little shameless behaviour in the past
I just wonder if this device is necessary to reduce the stress on the drivetrain and by removing it you increase the risk of damaging something expensive.
2008 Dark Grey Metallic STI
Mods: Stage 1 94 Custom tune | Kartboy f/r shifter & TiC pivot bushings | StopTech SS brakelines | Whiteline 24mm adj. front and 22mm adj. rear swaybars & front brace | RCE springs | Cosworth oil control baffle | STI competition engine & tranny mounts | NGK 1-step colder plugs | Group-A pitchstop mount & front/rear endlinks | MadDad EL header
2009 DGM WRX265 (wife's car)
SOLD - 2005 Aspen White STi
Digitalfiend is offline
Old 08-17-04, 07:53 PM   #6
salaki
True but I can handle it.
You can always adjust the way you drive.
I don't drag race or launch @ 5K rpm at all.
Mostly rev match during twisties drive or spirited drives.
I am sure this restriction is added by Subaru so those "other people" won't be able to abuse it that much..
Just put the clutch stainless line w/ ATE Super Blue.
It grabs slightly faster and clutch feel slightly heavier..
I like it.. realy precise.
BTW.. here's a link to buy clutch line for cheap:
http://www.roadraceengineering.com/ecldrivetrain.htm
(scroll down.. $20 bucks something shiped)
Make sure you get the one for the 2G ('95-'99) Ecllipse instead of 1G.
It's longer than Subaru OEM but it fits fine w/ some extra rerouting.
Looking forward to remove all the restriction.
Or if I think it's too much... I can always put it back to stock.
Clutch delay valve repost (with pics)-dsc03831-jpg
salaki is offline
Old 08-17-04, 08:46 PM   #7
Scuba_Steve
Master Contributor Level 2
Feedback Score: 2 reviews
Car: GT35R 04 STi
Fav Mod: E85
Scuba_Steve is an unknown quantity at this point
Hmmm? I can burn all 4 at will, cut 1.6 60fts or drive it like a grandma and the clutch feels fine. So what is the benefit of this mod?
Revolutions Performance-(719)635-6200
J&S Polishing-(719)477-9484
Exedy USA
Scuba_Steve is offline
Old 08-18-04, 07:45 AM   #8
bikerboy
Becoming A Contributor
bikerboy is an unknown quantity at this point
You can find the bolt at any oil change place it is a standard drain bolt for many cars.
A drain plug bolt might be a little shorter in the threads, I would screw it completely in the master cylinder and if it goes all the way in then ditch the copper washers and reuse the stock washer. This is only if the flange on the drain bolt seats all the way on the master cylinder!
bikerboy is offline
Old 08-18-04, 08:41 AM   #9
AndyM
Advanced Contributor Level 1
Car: 04 Subaru WRX STi
AndyM is an unknown quantity at this point
wow thanks great directions. The pics help a ton too!
Arlington Heights, IL
AndyM is offline
Old 08-18-04, 08:49 AM   #10
bikerboy
Thanks it was the least I ould do to help the comunity
bikerboy is offline
Privacy Policy
