| The Next Petter Solberg | 1. brass brush and dremel it 2. i heard some acid will do it 3. buy new ones???? that's what i get for being lazy. i mean i tried all the spray on crap. nothing... i mean that stuff is on there really good. advice? thanks... This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: 07 subaru wrx sti Location: san francisco Posts: 122
IWSTI Addict since: May 2007 Trader Rating: (2) | i use purple power and a tooth brush and everything is gone just spray some of that purple power den wait like 30 sec or 1 min den brush den spray off with pressure holes den all the break dust is gone thats what i do. |
| | #3 | |
| STI Master Car: 04 Subaru WRX STi Fav Mod: Whooshing sounds Location: Death Valley Posts: 6,130
IWSTI Addict since: Nov 2003 Trader Rating: (11) | Quote:
I recommand a water pressure washer (electric one, no more than 1800 psi) and special teflon brushes, P21S wheel cleaner, some sort of wheel polish. 2. Dremmel tool, polishing tip. (something delicate, yet strong). I'm not an expert on the dremmel tips, so read the instructions. You want something that will take off the chunks of brembo dust, but not the finish on the wheel. Wash the wheels with a strong stream of water, apply P21S, let that sit for a while. Scrub the wheels with your brushes. Hose the wheels down. Apply the wheel polish/creme to the areas with the caked dust. Start working with the dremmel. The caked dust should start comming off. Repeat as needed until you got all of it. Repeat on the rest of the wheels. | |
| | #4 |
| Senior STI Driver | How bad can it be? I believe I picked up a bottle of P21S (i think it was) and it took all the brake dust off with no problem. I have tried about 3 or 4 other brands and they wouldnt even touch the dust compared to it. But I dont think I would try anything on your list and I would listen to Peleg's advice. He seems to know his stuff about car detailing. Good luck |
| | #5 |
IWSTI Addict since: Nov 2003 Trader Rating: (11) | I actually saw exactly what the OP mentioned on a BMW. The dust adhares to the wheel in such way that a cleaner alone will not take it off. |
| | #7 |
| STI Guru
Car: 05 CGM STi Fav Mod: grip. Location: Southeastern PA Posts: 5,777
IWSTI Addict since: Aug 2006 Trader Rating: (7) | jesus... some of the suggestions are pretty crazy... oven cleaner? i would never let that **** touch my wheels haha... peleg definitely has the right idea... but i wouldnt use a dremel... i tried it on one of my wheels and ended up burning a slight hole in the paint because it just got too hot and got too many abbrasives on the tool i was using... however i was able to tackle HUGE amounts of very annoying race pad dust with a rubbing compound... i use my most aggressive swirl remover compound (PB SSR3) and scrubbed by hand with a terry cloth... the wheels now look almost brand new... i coated them with protectant afterwards and now the dust practically rolls off the wheels when washed. |
| | #8 |
| Professional STI Racer Car: 06 Subaru WRX STI Location: Hurst, TX Posts: 716
IWSTI Addict since: Jun 2006 Trader Rating: (1) | I personally found that Meguiars hot rims ($6) ended up working just as well as/ poorly as the P21S Gel($16). If you have to use the brush and start scrubbing just save yourself $10 and get meguiars |
| | #9 | |
| Silver Member Car: 06 Subaru WRX STI Fav Mod: My 20g Location: Topsham Posts: 785
IWSTI Addict since: Jun 2006 Trader Rating: (7) | Quote:
Has the citris juice in it. Wash the rims as good as you can when you are done with that spray Goo gone on and then it will almost wipe right off. This is how I do it. Have 06' with the Gold BBS and it is a pain keeping them clean. | |
| | #10 | |
I wonder if spraying the area with water as you work would resolve that. | |
| | #11 |
| Platinum Member Car: 06 Subaru WRX STi Location: Riverside, CA Posts: 1,205
IWSTI Addict since: May 2006 Trader Rating: (2) | I take my wheels off the car and pressure wash them one buy one. With the gentle nozzle that came with my gas powerd pressure washer not sure the psi off the top of my head. That gets most of it off except were the lug nots were and right up against "spoke walls" around the rim. Then a scrup them with a brush. Usually if If i scrub it for a Min then pressure wash it it comes off. |
| | #13 | |
| STI Guru
IWSTI Addict since: Aug 2006 Trader Rating: (7) | Quote:
| | #14 | |
| STI Guru
| | #15 | |
| STI Guru
