Old 02-06-2008, 06:41 PM   #466
STI Guru
Fav Mod: Whooshing sounds
Default Re: Peleg's Guide to Detailing
Beautiful Brew.
I just wonder how can one own a GREAT car like a 98 Supra TT and drive it looking like that.
I would have pulled over and punch myself...
Old 02-06-2008, 06:48 PM   #467
Car: 07-STi
Yup,i give this 6 stars out of 5.
VROOM293 is offline   Reply With Quote
Old 02-06-2008, 06:57 PM   #468
STI Guru
Brew, please tell me this guy let you at least drive the car after the detail.
Old 02-06-2008, 07:28 PM   #469
Fav Mod: CAR LIFT & Protune!
wow. ive been looking for a good sealer for my paint. when my bro bought his LGT he slipped the prep guy 50$ and he put some sealant on there that was amazing... the dirty ass LGT would be sprayed with the pressure washer and it looked brand new... this stayed on for like 6 months... i need some heavy duty stuff. peleg (and others) any recommendation? thanks in advance
Old 02-08-2008, 02:38 PM   #470
Car: 89 GT-R32
Fav Mod: no brake fade
Send a message via AIM to BrewPubeaver Send a message via MSN to BrewPubeaver Send a message via Yahoo to BrewPubeaver
i did get to drive it. but i didnt get on it. The tuner said the rear wheels would comeout when ever he wanted....
shame it was an Auto
BrewPubeaver is offline   Reply With Quote
Old 02-12-2008, 07:29 PM   #471
STI Guru
First of, wash this car and claybar the paint before anything. This will take off whatever is on the paint so you can start fresh. Meguiar's mild clay and Wolfgang clay lube should do the trick here.
After the car is clayed and dried, if you got swirl marks, a polisher and Mezerna intensive polish can take out swirls and scratches.
Then it is time for final polish to make her shine.
As for the sealant, I personally don't use it. I just go with good wax like Meguiar's #26.
If you still want the sealant, go to:
Paint Sealants like Klasse, Wolfang Deep Gloss Paint Sealant
Meguiar's or Wolfgang are good.
Old 02-18-2008, 02:12 PM   #472
STI Guru
9 hours of fun yesterday......In all 4 years of owning this car, I personally think this was the most intense detail day I've ever put into it. EVERYTHING was catered for......
Old 03-01-2008, 08:39 AM   #473
STI Guru
Default Quick exhaust detail
This is an easy way to make your exhaust tip like new again. You can do it after you wash the car or if you want a quick fun Saturday project.
Materials needed:
P21S Total auto wash.
Fine steel wool.
A good metal polish. If you don't have some, you can use final detailing polish.
An old rug or a mitt you won't be using on the paint.
A. Spray some P21S into the exhaust tip. Start rubbing the inside with the steel wool. This will take off all the carbon build up. Wash with some water. Repeat until all the carbon build up is gone.
B. Spray some P21S on the outside of the tip and let it sit for about a minute. Clean with the rug and wash off.
C. Apply some polish with another rug to the outside of the tip. Let that sit for about 2 minutes.
D. Buff off the polish.
Old 03-17-2008, 09:50 AM   #474
Car: Blue 07 WRX STI
Fav Mod: Soap
Peleg,
I've run into some issues with windows. I use the Stoner's Invisible Glass spray. I've also tried the run of the mill Armor All window spray. There are certain dirty spots that do not come off.
I am curious if this is under the tinting of the windows (still factory tinting). Nothing seems to touch it. You can only see it when staring into the suns reflection.
Also, what type of tape do you use to detail? I need to use some when I polish and wax the roof.
STI Sibb is offline   Reply With Quote
Old 03-26-2008, 06:09 PM   #475
Car: 07 OBP STI
^ i got the same exact issue with stubborn water spots on my rear window right under the roof vane (apparently i've been forgetting to wipe that area dry after some washes) ...thanks in advance for any advice/info you or someone may contribute to solving this issue
Old 03-26-2008, 06:23 PM   #476
STI Guru
Claybar and clay lube the windows, this will take off everything off the windows. They will be smooth like the paint afterwards.
Old 03-26-2008, 06:27 PM   #477
Car: 07 OBP STI
clay lube? > the detailer's spray that come with the kit?
Old 03-26-2008, 08:20 PM   #478
STI Guru
Correct.
Do so when you wash the car and rinse the soap off.
My favorite is the Wolfgang clay/lube combo from autogeek.
Old 03-26-2008, 08:24 PM   #479
STI Guru
Originally Posted by STI Sibb View Post
Peleg,
I'm not an expert on tinting, but if you don't have aftermarket tinted windows, the claybar will take your windows to a new level if you use it correctly when washing the car.
The tape I use is 3M blue tape from the hardware store. This is to make cleaning the polish easier so it doesn't get into all the hard to reach areas.
Old 03-31-2008, 06:04 AM   #480
Car: 07 OBP STI
Claying did in fact smooth out the windows dramatically...however, it did not take out the stained water spots in my rear window unfortunately...any other solutions you may possibly have?
