| Junior STI Driver Car: 06 STI Blue/Gold Fav Mod: Topspeed Location: Georgia Posts: 196
IWSTI Addict since: Jan 2006 Trader Rating: (0) | Okay, I just got my Zaino kit in the mail. Now I have read the web site and a few other webs sites on the application and to tell you the truth I am confused. If anyone is familiar with the application (with the ZFX kit) please comment on what steps I think I need to take. I truly believe that the instructions are overly complicated from Zaino. Now this is with the ZFX Additive! Step 1. Wash car with Dawn (blue) Step 2. Clay bar and use Zaino Car wash for lube (1/2 cap full and 12oz of water). Then wash car again. Step 3. Apply Z5 that has been mixed with ZFX (4 drops of ZFX to 1 ounce of Z5) Step 4. Add another coat of step 3 if needed and again if needed… Step 5. Apply Z2 that has been mixed with ZFX (4 drops of ZFX to 1 ounce of Z2) Step 6. Apply more coats of Z2 as needed or until bottle is empty. Does this sound right to the Zaino experts here? The Zaino site just confuses me to death. I just don't want to f-up my paint. Trust me I know to get rid of water spots before application. To you that reply thank you in advance. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver | I agree wtih you about the instructions, but once you've done it a couple of times you'll have it down. You can also call them up and they will give you all kinds of help. I think having the newer ZFX instructions and the older z-1 instructions confuse things a lot. I've had Zaino on my car since the beginning, so I might be able to help you out. The first year or so I used Zaino, I didn't use the claybar, but added it later. The Zaino instructions say to clay it first then use dawn, but you'll want to start with a clean car anyway, so your steps 1, 2 and 3 will work. To use your format: 1) Wash car with Dawn 2) Caly car according to instructions 3) Wash car again with Zaino wash 4) Mix your ZFX w/ z-5 and apply per instructions, then wipe off 5) Apply z-6 according to instructions and wipe off 6) Add a z-2/z-5 layer per instructions, then wipe off 7) Apply z-6 again 8) And final z-2 layer 9) And z-6 again 10) Done! You can apply from 1 to 3 coats of ZFX & Z-2/Z-5 in one day. I usually get tired after 2 coats. The z-6 in between is also another step so you're really going over the car multiple times for each application. Since I usually do two applications, I use z-5 for the first one, then z-2 for the second one. If I'm only doing one application (say in a couple of months or so after doing a "full" Zaino job), I'll just do one application of z-5 or z-2 depending on what my paint looks like or how much of one I have on hand . If I want the most gloss possible, I'll use z-2, if the swirls on my black car have been bugging me I'll do z-5. I also only clay it once, maybe twice a year.My one tip to you is use all Zaino stuff SPARINGLY. Whenever people are not getting the Zaino results they think they should, the recomendation I hear fist is use less. You won't mess anything up with Zaino, so just give it a shot and see how you like your results. /zp |
| | #3 |
IWSTI Addict since: Jan 2006 Trader Rating: (0) | Thanks for the reply. So just to clarify one thing in step 4 you listed, that is the only time I add ZFX? or do I have to add ZFX to the Z2 and other coats of Z5 after step 4? |
| | #6 | |
| Moderator Elite
Car: 2005 Subaru WRX STi Fav Mod: Underglows Location: Tyler, Texas Posts: 8,939
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Quote:
So here's what I do: 1. Wash with dawn (I never did this with any of my cars, because claybaring has the same results, though some people like to dawn and claybar to make sure all old wax and contaminents are removed). 2. Claybar (you don't have to use the car wash and water mixture, I use straight tap water with a spray bottle and that works fine for me). 3. Wash again (with or without dawn) to remove claybar residue (again, on my last 2 cars I didn't do this but I did wash it with my STi). 4. Apply Z-5. 5. Remove Z-5 (repeat #4 and #5 again if necessary). 6. Apply ZFX and Z-2. 7. Remove Z-2 (definately repeat #6 and #7 again as many times as you wish. I apply at least one coat of Z-2 every month). In between coats you can spray Z-6 to make the shine look even better. There's also some even better stuff than Z-6 (I think it's Z-8 or something like that) but Sal says to only use it for car shows since it's so expensive for everyday use. I use Z-6 to clean my car between washes when I get dirt on it. Also make sure to apply the Z-5 and Z-2 in vertical motions (up and down) when doing parts of the car that are verticle (i.e. doors, front bumper, trunk, rear bumper, etc.) and use horizontal motions (side to side) on parts of the car that are horizontal (i.e. hood, roof, top of trunk, wing, etc.). This really does make a difference in how the car looks when taking off the Zaino. | |
| | #7 | |
| Moderator Elite
| | #8 |
| Moderator Elite Car: 04 Subaru WRX STi, W Fav Mod: KartBoy SS & Bushings Location: Illinois Posts: 8,746
IWSTI Addict since: Jan 2001 Trader Rating: (0) | Correct. I use Klasse and the initial application has just as many steps, including multiple coats of Klasse SG. Of course you don't have to apply multiple coats of SG just like you don't have to apply multiple coats of Zaino. |
| | #10 |
| STI Driver Car: 05 Subaru Fav Mod: WRX STi Location: New Fairfield Posts: 274
IWSTI Addict since: Nov 2004 Trader Rating: (0) | I also use Klasse and let me tell you using multiple coats of the sealant glaze is amazing. I did all the prep work and did one layer of Klasse All-in-One. Then I put on one coat of sealant glaze, let it sit for 4 hours, put on a second coat and let it sit for a couple hours, and then a third coat sat for overnight. When I took the third coat off the car just looked rediculous. I had so many people just stare in awe at the STi, even a 911 GT2 owner. He came up to me and asked what I used to clean it |
| | #11 |
| Moderator Elite
IWSTI Addict since: Jul 2005 Trader Rating: (0) | ^^ I get the same thing with Zaino. To each their own. |
| | #12 | |
| Junior STI Driver | Quote:
The ZFX is required for the Z-2/Z-5 to properly cure and dry on your car so you can buff it off quickly. /zp Last edited by zp2063; 03-23-2006 at 08:15 AM. | |
| | #13 |
| Junior STI Driver | I've been using Zaino since I got my STi and I like it a lot. My buddy has a used car place and he needs to detail cars quickly and get good results so he uses Klasse all-in-one. He says it's a jack of all trades. He just got me some to try, so I might strip the Zaino and give the Klasse a try. I think I can use a Random Orbital with the Klasse, but using that with the Zaino would be a waste I'm told as so little product is required. /zp |
| | #14 | |
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Quote:
| | #15 |
IWSTI Addict since: Jan 2006 Trader Rating: (0) | Thanks again everyone for the help. A few weeks back while my wife was driving the car a deer ran out and hit the side of the passenger door. Not much damage to the car ($1,300) worth. Just two small dents on the door. The body shop did an amazing job. Looks new again. I had to buy the Zaino to get over the guilt I feel. Damn $500 deductable, that came out of my TS350 fund. This ad is not endorsed by this member. Please register or login to hide this ad. |
