Old 10-09-2005, 12:52 AM   #1
Car: 05 Subaru WRX STi
Send a message via AIM to Bunghollio
Default wax?
i have many swirl marks on PSM that u cant really tell but when the light hits it just right u can see fine circuler scratchs if i wax the car would it take all all those small swirls off? ( ive never waxed my car ever )
Bunghollio is offline   Reply With Quote
Old 10-09-2005, 01:04 AM   #2
Car: 05 AW STi
Fav Mod: APS 3.5 exausht
ya it should if you do it right.
STI Rocker is offline   Reply With Quote
Old 10-09-2005, 07:07 AM   #3
You need a polish or paint cleaner to remove/conceal swirls (depending on how deep they are). Wax won't do it. Search in the Exterior forum for swirl marks and you'll find threads on 30 different products that do the trick. I used a Meguiars 3-step product called Deep Crystal System. I had very light swirls in my clearcoat, and after many hours of using this method, they're gone.
klaymon is offline   Reply With Quote
Old 10-09-2005, 10:20 AM   #4
Fav Mod: Track Time
Find a good swirl remover, 3M makes a few. Just get some and do a few coats to get rid of the marks then wax and polish over it. Make sure your car is completely clean. Don't go cheap either. Get a good wax like Zaino or Meguiers. Do a search if you want the Meguiers. I can't recommend which to get becasue I use Zaino.
WE_R_ND is offline   Reply With Quote
Old 10-09-2005, 10:38 AM   #5
Car: 05 WRB
Really, the only way to remove *all* swirl marks is to use a good dual-action orbital buffer, or a rotary if you have the skills or know someone who does.
Since you have never even waxed your car yet, I suspect you don't. If you can afford an STi, dropping another $130 for a buffer shouldn't hurt you too bad.
Check out this earlier thread for a better explanation. You can achieve incredible results.
*Get Rid* of Swirl Marks = Menzerna
Keep in mind I just went to a local car show last night, and out of probably 60 vehicles only *one* had a properly taken care of, swirl free finish. We are talking about beautifully done HemiCudas, vintage Ferraris, that were *tore* up under the evening lights.
Seems to be an epidemic, which is a shame because all it takes is purchasing a buffer and some decent product to get things near perfect.
Alcheringa is offline   Reply With Quote
Old 10-09-2005, 10:47 AM   #6
Car: 05 WRB
And KLAYMON is right. Unless it is a cleaner/wax, the purpose of a good quality wax is to shine and protect *after* you have compounded or polished imperfections away. It will not contain any of the abrasives necessary for rubbing it out.
1) Compound (deep scratches and swirls, hard-water etching and spots)
2) Polish (normal swirls and light water spots)
3) Glaze (this is the *filler* you are thinking of--like *makeup* for a car)
4) "Wax" (synthetic or carnuba)
Everyone has their own brand, but as a rule don't go cheap and you'll get great results. I wouldn't deviate far beneath Meguire's, and their *Professional* line at that. Not that much more expensive, and manufactured to be used with a buffer.
