Old 04-28-2005, 08:16 AM   #1
Village Idiot
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
Default Clay Bars
I just used a clay bar on my car yesterday, and let me just say it's amazing!! It only took about 30 min longer then a regular wash and wax, but now the paint looks just like it did the day I bought it. I guess I didn't realize just how "dirty" the JBP paint had become. If you have done any driving though snow or rain for any amount of time I would definatly recomend doing this. I just used the "Mothers Clay Bar Kit" from Auto Zone, cost about $18.00 and was worth every penny.
Later Chris
Old 04-28-2005, 08:33 AM   #2
Fav Mod: Dyslexia
Trader Rating: (13)
You think this would help with an Acid Rain problem?
Old 04-28-2005, 08:40 AM   #3
Trader Rating: (71)
Send a message via AIM to Paperchasin
clay bar removes grime and other gunk regular washing doenst get off...and yes, it is amazing how well it works...but i dont think it'll help any if u have paint damage....
Paperchasin is offline   Reply With Quote
Old 04-28-2005, 08:50 AM   #4
Village Idiot
Car: 04 JVP STi
You might give it a shot, kinda depends on how bad the damage is, it won't hurt though. It take os oxidation and water spots really well so it might help with acid rain.
Old 04-28-2005, 09:42 AM   #5
When you clay your car, do you have to strip all of the old wax off first?
Moops is offline   Reply With Quote
Old 04-28-2005, 10:08 AM   #6
Trader Rating: (71)
yes...
Old 04-28-2005, 10:19 AM   #7
Car: 1983 Mercedes Benz 3
The clay bar takes off the old wax. More important, you need to wax right after, as your paint is exposed to the elements.
Ol'SaltyBastard is offline   Reply With Quote
Old 04-28-2005, 01:09 PM   #8
GT R US
although the clay bar will probably remove the wax, i wash the car with dawn dishwashing detergent (per zaino's instructions in a bucket of water) first to remove the old wax before i use the clay bar. you won't believe how smooth the paint surface feels after being clayed compared to unprepared surface. as odb says, wax it right away.
Old 04-28-2005, 01:16 PM   #9
Trader Rating: (71)
matter of fact, i use spray wax while i clay bar...then wax it again on top of that...
Old 04-28-2005, 01:17 PM   #10
With JBP I recommend polishing(I use 3M polish for dark colors) before waxing. Really gives the car a deep, wet look.
Boxer is offline   Reply With Quote
Old 04-28-2005, 01:30 PM   #11
GT R US
are you using the detail spray as a lubricant?
Old 04-28-2005, 01:31 PM   #12
Trader Rating: (71)
no...its the spray that came with the Mother's clay bar kit that i have....
Old 04-28-2005, 01:39 PM   #13
GT R US
last fall when i clayed my car for the first time i used mother's kit including the spray that comes with it. and it was great. this time i'm using zaino's clay bar and these are the instructions for using it.
Zaino Z-18™ ClayBar was designed to remove airborne contaminants, paint overspray, water spots, rail dust, industrial fallout, diesel fuel & catalytic converter residue and any other bonded surface contaminants from paint. All cars even brand new factory paint has airborne contaminants... Here's the deal. The non-abrasive Z-18™ ClayBar will remove any surface contaminants from the paint finish and not hurt the clear-coat. The ClayBar will get that paint finish smooth as glass. Now remember waterspots, bird droppings and bug guts if left on the paint finish for any length of time, will etch into the paint finish. The ClayBar will also remove any store bought waxes....
I recommend you use my car wash (Z-7) as a lubricant for the ClayBar. Just make sure to keep the surface area lubricated while using the ClayBar. Use 1/2 capful of Z-7 Car Wash to 12 ounces of water. I use a spray bottle for the mix. Shake it up and spray the area to be Clayed. Just make sure to keep the surface area lubricated while using the ClayBar.
3. I would definitely recommend you remove the wax buildup on your paint. Just use Liquid Dawn (hand dishwashing liquid) as a car wash. It has a high alkaline content which cuts right thru carnauba wax, paraffin, silicone oils, etc. This will get your paint finish squeeky clean and wax free.
I don't advise making a habit of washing your car with Dawn. But for this scenario it's fine. High alkaline products like Dawn are tough on polishes. It will never harm the paint finish though. A car wash is made specifically to clean without removing durable polishes. ALSO, Make sure you remove any water spots, before you apply my products. Because Zaino has no abrasives or harsh solvents it will not remove water spots or stains. Z-18 ClayBar is great for removing any paint surface contaminants. Re-wash the entire vehicle with Z-7 Car Wash immediately after the ClayBar
Cleaning Process.
Old 04-28-2005, 07:46 PM   #14
Car: 04 STi wrb
Fav Mod: not even a radio yet
I recommend you use my car wash (Z-7) as a lubricant for the ClayBar. Just make sure to keep the surface area lubricated while using the ClayBar. Use 1/2 capful of Z-7 Car Wash to 12 ounces of water. I use a spray bottle for the mix. Shake it up and spray the area to be Clayed. Just make sure to keep the surface area lubricated while using the ClayBar.[/i]
The last time I Zaino-ed my car, I used Z-7 plus water as a lubricant for the clay bar. The Z-7 was okay, but I found using BeadX detail spray much better. The clay bar glided better with BeadX (made by Formula113).
chancers is offline   Reply With Quote
