| Lurker | I own a 2008 sti and would like to remove as many badges as possible. What is the friendlest and easiest way to remove badges from my STi. I figure I should remove the badges as soon as possible before the color changes from UV exposure This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: '06 STI Fav Mod: Stage dos Location: The dirty den, CT Posts: 56
IWSTI Addict since: Nov 2007 Trader Rating: (0) | I found Goo Gone's sticker/decal remover works really well. It even comes with a nice little plastic scraper that isn't abrasive to the clearcoat. |
| | #3 |
| Platinum Member Car: 06 STi Fav Mod: Buying a beater for DD Location: DE/PA border Posts: 1,318
IWSTI Addict since: Nov 2006 Trader Rating: (5) | Use a hair dryer to warm up and soften the adhesive 1st. Using fishing line helps to remove the emblems from paint w/o scratching as long as you KEEP the adhesive hot and soft. Then follow with googone than paint cleaner/polish and wax quickly after. I say quickly because of the thin paint/clearcoat. No need to run around though. Easy. |
| | #4 |
| Silver Member
Car: 2004 SRR WRX Fav Mod: 50mm f1.7 Location: Westchester, NY Posts: 129
IWSTI Addict since: Aug 2008 Trader Rating: (0) | ^ And if you don't have fishing line, dental floss works just as good. |
| | #5 |
| STI Driver Car: 2005 PSM STi!!!11 Location: North Jersey Posts: 216
IWSTI Addict since: Oct 2007 Trader Rating: (2) | In addition to what never ending mods said, after you heated up the badge and have taken it off, apply Goo Gone and/or Bug and Tar remover and then be sure to heat up the adhesive again to make it easier to get rid of the adhesive. ...I just realized you posted this about 30 days ago and you probably already did it but I am going to post this anyway since I typed it all out. |
| | #6 |
| STI Driver | I just pulled the badges off my Wife's 08 Tribeca. Just leave it out in the sun for an hour. I didnt fool around w/line, I just wrapped a pair of pliars jaws w/tape, gripped the badges w/the jaws (away from the paint) & just slowly pulled away from the car (straight away from the car to avoid contact wthe emblem & paint). The emblems all came off easily & took the adhesive w/them. Just take it slow & the adhesive should pull away from the paint & stay attached to the emblems. No mess & just wiped it over w/a damp cloth & dried. |
| | #7 | |
| Junior STI Driver | Quote:
| | #8 | |
| | #9 |
| Junior STI Driver Car: 2006 OBP STi Fav Mod: Driving Location: California Posts: 152
IWSTI Addict since: Jul 2008 Trader Rating: (0) | So wait sorry this sounds stupid, (sorry i don't know anything about goo gone or decaling anything) but when you say adhesive are you referring to the product made by goo gone? like the product they sell is called adhesive? sorry. |
| | #10 |
| Silver Member
IWSTI Addict since: Aug 2008 Trader Rating: (0) | The adhesive he is referring to is the gooey stuff behind the emblems. It hs to be heated up enough for it to be easy to take off. The goo-gone is the liquid that help take off the adhesive. |
| | #11 |
| Amateur STI Driver Car: PSM 05 WRX STi Fav Mod: Good shoes Location: San Diego Posts: 44
IWSTI Addict since: May 2008 Trader Rating: (1) | No, they are referring to the original 'glue' (=adhesive) which Subaru used to attach the badges in the first place. The Goo-Gone and similar are products used to clean up any remaining adhesive where the badge was, once you get the badge off. |
| | #12 | |
| Senior STI Driver
Car: 05 PSMud STi Fav Mod: LWG map to fix overboosting Location: Richmond, VA Posts: 370
IWSTI Addict since: Aug 2007 Trader Rating: (0) | Quote:
I used a hairdryer and dental floss to get mine off. Once they were off and sprayed the leftover adhesive with WD-40 and then heated it with the hairdryer and once you get it hot enough, it will almost peel right off. BTW, I used that flat tape-like floss and that stuff broke 2-3x per letter. I recommend using the older rounded floss. | |
| | #13 | |
IWSTI Addict since: Nov 2006 Trader Rating: (5) | Quote:
