Old 08-07-2008, 03:25 PM   #1
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
IWSTI Addict since: Jan 2007
Default STi door panels...
It seems the blue cloth pieces on my doors seem to need a cleaning. What kind of fabric/cloth cleaner has worked well for others?
C.J. is offline   Reply With Quote
Old 08-14-2008, 12:00 PM   #2
Car: 05 WRX Sti
IWSTI Addict since: Oct 2007
Default Re: STi door panels...
Bump for that one too!! With the OEM Seats, What to use on them?
WhiteNite is offline   Reply With Quote
Old 08-18-2008, 05:00 PM   #3
IWSTI Addict since: Mar 2007
BUMP! ditto!
kayno is offline   Reply With Quote
Old 08-18-2008, 07:34 PM   #4
Car: Silver 05 WRX STi
IWSTI Addict since: Jun 2008
I'm sure there are some specialist products out there for this but this is my ghetto DIY way of cleaning the upholstery.
Get a bucket of warm water, add some liquid soap to it (dish soap, shower soap, doesnt matter as long as it foams). Then agitate the water/soap solution in the bucket so that it's nice and foamy. Then with a damp cloth I put a blob of the foam only, not the water/soap solution, on the dirty area, some rubbing and the stain is usually gone.
The idea with using the foam only is that it doesn't wet anything. I still let it dry for an hour or so, then vaccumm and good as new.
sti_v9 is offline   Reply With Quote
Old 08-19-2008, 02:40 PM   #5
Car: black 05 WRX
IWSTI Addict since: Aug 2008
yo i use turtle wax qxy cleaner it cleans up anything and it makes your car smell like new
05p&lrex is offline   Reply With Quote
Old 08-20-2008, 01:47 PM   #6
Car: Black 08 WRX STi
Some professionals don't care for it, but a 10:1 solution of Woolite is a good, inexpensive all-purpose interior cleaner. In fact, some manufacturers specify it as the cleaner of choice for leather. However, since it contains detergents, a couple of caveats apply. First, you should be careful to dilute it as specified, and you should not let it soak in and remain on your interior surfaces. A wipe-down with a wetted cloth--and possibly extraction with a carpet/upholstery steam vac--will eliminate any ill effects from residue that might otherwise remain.
Griot's Garage also sells a multipurpose interior cleaner that I've found effective on everything inside my cars.
MikeBoom is offline   Reply With Quote
