Old 06-02-2008, 05:38 PM   #1
Default Foam Alternative to Clay Bar?
Has anyone used one of these foam blocks that are supposed to be better than clay barring? Here's a link to one, but if you type "clay bar foam" into google, you'll get a few products that use the same foam chunk. I have a bunch of Meg's detail spray, so I'd like to see if picking up one of these foam things would be a good idea. Please let me know what you think.
Ultima Elastrofoam Paint Cleaning System
Jacob
renob123 is offline   Reply With Quote
Old 06-02-2008, 06:01 PM   #2
Fav Mod: Boost gauge
Default Re: Foam Alternative to Clay Bar?
looks interesting. Kinda pricey though.
USNSTI is online now   Reply With Quote
Old 06-02-2008, 08:47 PM   #3
This one looks a little pricey, but you can get the same thing for around $10. I just linked to this one because it had a better description. Plus you can "clay" 20 cars with just this one thing, vs. maybe 4 with regular clay. Still interested to see someone's opinion on this stuff.
Jacob
Old 06-03-2008, 03:10 AM   #4
STI Guru
Fav Mod: grip.
sounds rather gimmicky to me.
chaos311clarity is online now   Reply With Quote
Old 06-03-2008, 06:02 AM   #5
STI Guru
Fav Mod: Whooshing sounds
I'll stick with the Wolfgang claybar/lube.
Old 06-03-2008, 08:55 AM   #6
Car: 2007 WRX TR
Don't mean to thread jack, but I was under the impression that a clay bar is only good for a one time use. Is this true?
Dirty TR is offline   Reply With Quote
Old 06-03-2008, 08:57 AM   #7
STI Guru
Fav Mod: grip.
not at all... an acutal clay bar can be molded around/flipped etc to get a clean section to use.
Old 06-03-2008, 09:02 AM   #8
Car: 2007 WRX TR
Good to know. That will save me money in the long run, thanks.
Old 06-03-2008, 09:30 AM   #9
Car: 06 Subaru STi
Fav Mod: Deadbolt 20G
Jacob
If it won't remove wax, then I don't see how it can be as effective as clay bar.
Okeyd57 is offline   Reply With Quote
Old 06-04-2008, 05:05 AM   #10
STI Guru
Fav Mod: grip.
claybars dont remove wax. thats not their intended use at least.
they are meant to remove contaminants in the paint.
Old 06-04-2008, 06:48 AM   #11
STI Guru
I'll have to correct u on that one, they remove everything that sits on top of the clearcoat, dirt, wax, polish, glaze, etc.
Old 06-04-2008, 06:50 AM   #12
STI Guru
Good for about 3 times (3 cars) depending on how much dirt it collects.
You have to mold it into a ball and than into a waffer again to reveal more clean surface as you go around the car. Once the claybar is totally dirty, its done its job. You can then use it on the windows or toss it away.
Old 06-04-2008, 06:52 AM   #13
STI Guru
Fav Mod: grip.
we can agree to disagree then
either way clay bar is full of win and should be used by everyone when properly detailing a car.
Old 06-10-2008, 02:54 PM   #14
Jacob
Hmm, it looks like nobody has actually used one of these things before...
Jacob
Old 06-10-2008, 03:17 PM   #15
Trader Rating: (14)
Looks good to me. It's just another "catchy" type medium that can be used in the same way as claybar. And I too belive claybar removes "everything" on top of the clear coat. And helps pull out other debri from the clearcoat. It also removes the debri from the wax coat, thus removing the wax it self. It's a know fact to wax you're car after a full clay job. Or else you're paint is "naked"..
