Old 05-30-2008, 08:11 PM   #1
IWSTI Addict since: Mar 2007
Default Smoke detailed - 3 cars, 3 days: Bimmer's and Benz's
Last week was a busy one. For some ridiculous reason I ended up scheduling 3 cars back to back to back. 14 hours each or so. I'd finish one, drop it off and pick up the next the following day.
First up Merc E350...
Quick process summary, very similar on all cars
Makita
CM5300
Highline
ONR
Sonus green
Z-PC w. green ccs
3M UF w. grey ccs
Z6 wipedown
1x Z2pro ZFX'd
Z6 wipedown
P21s 100% x2
Z8
Prototype APC being tested on wheels and tires
EZ brush and Swissvax brush
AG intensive tar remover
Black WOW on trim
CG Liquid extreme shine on tires (heavy on the tire shine as per customers request)
Adams undercarrige
1Z glass polish
Noxon + #0000 SW
Z-AIO wheels polished
Z2 ZFX'd on wheels topped w. Z-CS
LGM w/ Folex
Megs APC+
Z9/Z10 on leather
1Z CP
1Z Reinger
Befores;
Prototype APC working its magic on the rear wheels...no powersticks needed
After
Front passenger side wheels, thick brake dust no match for E-Shine's APC, this stuff is truly a great wheel and tire cleaner
After
Noxon and Mf worked nicely on the chrome...
Sorry no outside pics on this one, afters
Smoke is offline   Reply With Quote
Old 05-30-2008, 08:12 PM   #2
Default Re: Smoke detailed - 3 cars, 3 days: Bimmer's and Benz's
Next up another Merc this time a beautiful S550...
Process changed for extensive paint correction
Menz SIP at 1500rpm w. Megs cutting pad, multiple hits on some areas
106ff w. white ccs
UF w. grey ccs
Z5pro ZFX'd
Z6
P21S 100% x2
Z8
Befores, ran out of battery so proceeded to polish while the camera was charging. Lots of water spots, buffer trails(from last detailer), heavy swirls and RIDS
After 2 hits with SIP, still RIDS left
Post polishing, No LSP
Final shots taken the next morning after applying 2nd coat of P21s 100% and Z8
Old 05-30-2008, 08:12 PM   #3
Last, BMW 650. Owner of the S550's wifes car. I dropped of his Merc and he handed me the keys to her BMW . This ones interior was pretty bad. Heavily soiled leather and carpets that needed a lot of attention. Paint was in very good shape however, fine swirls and very little bonded contaminants. Some areas measured close to 290microns! The cars clear averaged 150-170 microns if I recall correctly but some areas were clearly thicker than others. Leather needed more than Z9 so I used LM strong cleaner and the convertible got the Raggtopp treatment.
The carpets were a mess. I started with a thorough brush and vacuum. Then came the LGM with Folex as solution. That got out a good portions of the stains but no where near perfect. Followed up with 303 Spot remover in some areas then Megs APC+ 4:1 hand scrubbed and re-extracted with the LGM. Followd that with a vacuum then re-shampooed with Folex and left to sit for 20minutes, agitated and then pressure washed with the Kacrher at 1800psi, re-extracted then vacuumed and presto!
De-Junktafication...
Ziploc magic
Presentation is everything...
Not terrible but way above the average readings I was getting
After 106ff on a white ccs at 1500rpm. This was the best 106ff has ever worked for me. It broke down super smooth on this paint and I got "zero" dusting for the first time in 20+cars using it. I think making the switch to a rotary helped to show the full potential of SIP and 106FF.
After Ultrafina at 1700rpm
Wheels before special APC
Afters, cant help the curb damage done IMO it ruins the look of a cleaned wheel
Final photos... after Z2pro and P21s 100%
(Hood doesnt close properly)
For sure a grueling 3 days but the customers were all happy so I was happy.
Anyways thanks for looking. Good night guys.
Old 05-30-2008, 11:15 PM   #4
Car: aspen 2005 wingless
IWSTI Addict since: Sep 2006
sick!
Old 06-01-2008, 05:57 PM   #5
Car: 2007 WRX TR
IWSTI Addict since: Feb 2008
They look great, good job!
Dirty TR is offline   Reply With Quote
Old 06-01-2008, 06:07 PM   #6
i eat cones
Fav Mod: intake
IWSTI Addict since: Oct 2006
Trader Rating: (21)
sick work smoke.
