Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > General > Detailing & Car Care
Old 05-12-2008, 12:36 PM   #1
Car: STI
Default How to Remove light scratches from Gauge Cluster
Hello,
I noticed there are some light scratches (like swirl marks) on the clear plastic cover of my Gauge Cluster. I was wondering what would be the easiest way to remove these? Is there a product that can be used to remove very light swirl marks from clear plastic that can be applied by hand? I am sure a buffer would do the trick, but I am hoping I can find a solution that doesn't involve removing the gauge cluster (I've done it before and it is a PITA). Thanks!
Bloo is offline   Reply With Quote
Old 05-12-2008, 12:44 PM   #2
Car: 07 GDB-G WRB STi
Fav Mod: shift knob
Default Re: How to Remove light scratches from Gauge Cluster
There are products available for polishing plastics.
rs_wrx_sti is offline   Reply With Quote
Old 05-12-2008, 12:47 PM   #3
Car: '05 CGM
Fav Mod: HPDEs
Try Plexus helmet visor cleaner and polish.
A google search should help you find a source.
Gary
Old 05-12-2008, 01:52 PM   #4
Car: STI
...nevermind....
Old 05-12-2008, 01:57 PM   #5
Car: STI
Gary
Thanks for the suggestion. I did some searching on this product, and it looks like it is more of a wax/filler than it is a polish.
Anyone have other suggestions? Thanks!
Old 05-12-2008, 01:57 PM   #6
Car: '05 CGM
Fav Mod: HPDEs
Deleted
Old 05-12-2008, 02:23 PM   #7
Car: STI
I will just try Meguiar's PlastX. Thanks!
Old 05-12-2008, 05:33 PM   #8
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (12)
The only way to really remove the scratches is by machine polishing. Taking it out is really easy, takes 2 minutes.
Old 05-12-2008, 05:45 PM   #9
The Stig II
Fav Mod: Meth protune 323+/380+
Plexus is great on soft plastic windows (like on a boat top) but it really does nothing on hard plastic...
jnprn2003 is offline   Reply With Quote
Old 05-12-2008, 05:49 PM   #10
Car: UGM 07 WRX
Dunno if this might be a bit too aggressive, but check it out
Wolfgang Plastik Lens Cleaner will clean and clarify plastic lens covers!
Rain is offline   Reply With Quote
Old 05-15-2008, 02:53 PM   #11
Car: STI
Not when you have a stock boost gauge mounted on the steering column ...
Old 05-15-2008, 03:01 PM   #12
Car: 04 Platnm Silvr STi
Fav Mod: GT35R 450WHP Pump No Meth
Blue magic makes a plastic and acrylic polish. I used of on my cluster with near top notch results, it can be had at your local pep boys.
Old 05-15-2008, 08:09 PM   #13
Car: STI
Awesome, thanks for the info. I will go to Pep Boys and see if I can find it. Did you only have to apply it by hand?
Old 05-15-2008, 09:18 PM   #14
STI Guru
Fav Mod: Whooshing sounds
If you have a dremmel tool, you can get a polishing tip for it and use that. Just start at a very low speed and don't apply a lot of pressure.
Old 05-15-2008, 10:47 PM   #15
Trader Rating: (13)
do you think this would this be safe on Defi gauge surface?
