Old 04-07-2008, 06:56 AM   #1
Default The ultimate way to clean your wheels - AcePowerStick
Okay everyone I know these are expensive but they do the job and I have heard they do a good job from some of my pro guys.
Here is some info.....
INTRO per the ACE Powerstick site
We would like to introduce you to the ACE PowerStick automobile wheel cleaner. It’s simply the best device on the market to clean the inside edge of your automobile wheel without having to remove it from the car. This is a product we invented, manufacture and now distribute worldwide. The inspiration to invent the PowerStick was based on the founder
s own obsession to clean the inside of his wheels without having to remove them from the car, which he actually did! We found that the majority of wheel cleaning brushes on the market today are twisted wire brushes. These brushes tend to be abrasive and should the twisted wire touch the edge of the wheel, it will surely damage it, plus they were too short to reach into a deep wheel. The standard method to use a twisted wire wheel brush was manually using an “in and out” motion. We experienced that during the out motion, the bristles snap back at you and spray you with the dirty water. With the
PowerStick, since it is attached to a drill, the rotating motion of the cleaning fabric rotates within the wheel, keeping the user clean. It’s simply an easier, more effective way to clean a wheel.
Hundreds of hours were spent on developing the ACE PowerStick product line. A large portion of the PowerStick’s research and development time was spent locating the best components to produce it. The rods we use are thin enough to fit into any wheel, yet made of high density plastic that is extremely strong under stress. The outer surface of the rods are smooth and will not damage the wheel should it come in contact with it. The super-soft cleaning fabric, threaded through the rod, was developed for the car wash industry. It is extremely soft, very durable and will never damage a wheel under any circumstances. The PowerStick’s materials aren’t the only things that make it unique, its fabrication is as well. Our patent pending design encompasses [hand] threading the super-soft fabric through precisely positioned [hand] drilled holes in the rod. Although the PowerSticks seems to be somewhat simple, they are tedious to make, time consuming to produce and are made one at a time. Each PowerStick is completely hand made in the U.S.A. by our own team of certified Ace PowerStick engineers.
A great deal of time was also spent developing the most effective designs and sizes. There are 12 versions. They all work wonderfully, but differ from one another allowing the user to select the appropriate size(s) to clean any wheel quickly and thoroughly. Please visit our Models and Videos pages for detailed information on which PowerSticks work best in various applications.
Ace PowerStick Pro-Line
ACE PowerStick 2008
Model #401 is 14” in length and manufactured on a 1/4” diameter rod, the thinest rod in the PowerStick family. It’s threaded with of 6” with super-soft fabric which is 1/4” in width. The diameter of the fabric measures 2 3/4” when the PowerStick is spinning. This model is best for wheels that have about 3/8” between the inner wheel surface and brake disc or caliper and was designed for quickly cleaning a wheel where the brake disc or caliper are very close to the inner wheel surface, but a long PowerStick reach is required.
Model #P401
Model #P501
Model #501 is 16” in length and manufactured on a 5/16” diameter rod. It’s threaded with 6” of super-soft fabric which is 5/16” in width. The diameter of the fabric measures 2 13/16” when the PowerStick is spinning. This model is made on a slightly sturdier rod them model #401, but requires a little more space between the brake disc or caliper and inner wheel surface for it to spin freely. It’s a great choice to clean in front of and then behind the brake disc or caliper without the super-soft fabric binding up underneath it. The longer 16” rod is a nice addition.
Model #P601
Model #601 is 16” in length and manufactured on a 3/8” diameter rod. It’s threaded with of 9” of super-soft fabric which is 3/8” in width. The diameter of the fabric measures 3 7/8” when the PowerStick is spinning. This model is made on the sturdiest rod we offer, yet the super-soft fabric strips are thin enough to allow the model to work well in fairly tight spots. This is a great all-around model!
Model #P602
Model #602 is 16” in length and manufactured on a 3/8” diameter rod. It’s threaded with 9” of super-soft fabric which is 1/2” in width. The diameter of the fabric measures 3 7/8” when the PowerStick is spinning. This model is made on the sturdiest rod we offer and has the largest width super-soft fabric. This is a great all-around model where you have 1” space or more between the brake disc or caliper and the inner wheel surface.
Model #603 is 16” in length and manufactured on a 3/8” diameter rod. It’s threaded with 6” of super-soft fabric which is 3/8” in width. The diameter of the fabric measures 3 7/8” when the PowerStick is spinning. This model is made on the sturdiest rod we offer and has a long reach. It’s a great model where you have a tight area between the brake disc or caliper and inner wheel surface but want a the sturdiest rod. With this model you can clean on each side of the brake disc or caliper without the super-soft fabric binding up under it.
Model #P603
Model #P604
Model #604 is 16” in length and manufactured on a 3/8” diameter rod. It’s threaded with 6” of super-soft fabric which is 1/2” in width. The diameter of the fabric measures 6 7/8” when the PowerStick is spinning. This model is made on the sturdiest rod we offer and has the largest width super-soft fabric and the biggest radius when spinning. It’s a great model where you need a long reach and have greater then 2” of clearance between the brake disc or caliper and inner wheel surface. Due to the large spinning radius of the super-soft fabric, this is a great model for reaching behind wide spokes on the wheel.
Pricing is $46-50 dollars each stick
Click here to check them out.
Old 04-07-2008, 07:03 AM   #2
Car: Blue 04 WRX STi
Send a message via AIM to Coldfire
Default Re: The ultimate way to clean your wheels - AcePowerStick
Seems like it would work pretty well if you have narrow spokes with a lot of room between them. I think you would get a better clean by taking the rim off the car though.
Coldfire is offline   Reply With Quote
Old 04-07-2008, 07:12 AM   #3
I guess the whole point is to save time by not taking off your rims.
I've used this a few times on the wheels I have and so far no issues.
Also if you look there are 6 of them you can pick up the ones that work for your wheel/brake setup.
Old 04-08-2008, 02:11 AM   #4
Admin
Fav Mod: The Driver
Subie Love Subie Love
Platinum SEMA 2007 Sponsor How-To Contributor Award
HSPN Platinum Lifetime Member
How often do these need replacing and how well do they work?
These look very cool.
Kevin is offline   Reply With Quote
Old 04-08-2008, 05:29 AM   #5
they work very well, as for how long they last I have heard customers report quite a long time.
Old 04-08-2008, 03:24 PM   #6
Car: 07 OBD WRX STi
Thats super vague lol. Do you have any before and after shots? Last a long time like what 6 months? 10 uses? Any more info would be awesome. The idea looks good if they are effective and durable.
gormansscooby is offline   Reply With Quote
Old 04-08-2008, 05:13 PM   #7
I know its vague but I can tell you something last forever but for another user its last 2 weeks. I'm not sure what you want me to tell you but I had mine for 1 set of wheels and it looks brand new, that's about all the experience I have had with them. These haven't been in the market very long but the pros that I have spoken to have told me they have lasted them many many many sets of wheels hundreds. I hope that helps.
I can point you to the owner of the company and you can hit him up with questions as well.
I have asked about breakage and warranty he has told me confidently that he has had no returns yet or complaints from either distributors or end customers.
Old 04-08-2008, 06:55 PM   #8
Car: 07 OBD WRX STi
good stuff thats what i wanted to hear thanks. If it last 100 uses sounds worth it to me.
Old 04-08-2008, 07:18 PM   #9
sure thing.
