| Professional STI Driver Car: Blue 07 WRX STI Fav Mod: Soap Location: Winston Salem, NC Posts: 434
IWSTI Addict since: Apr 2007 Trader Rating: (0) | I've accumulated a few dings from other vehicles (2 bolts off of semi's). I finally got around to using the blue Subaru touch-up paint on my 07 and noticed a couple things. 1. It is a much darker shade when it dries. (I did used primer underneath, but no filler putty.) It looks like a perfect match when wet. It dries so quickly that you have to be accurate or you will just make it look messy if you go back over it a second time with the pen. 2. Applying clear coat afterwards can be a headache as you need to carefully wetsand the excess off and then use Meguiar's ScratchX to repair the discoloration. This works, but it takes forever as you have to do this several times to safely remove the excess without removing the original surrounding clear coat. Has anyone found a better method? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| STI Guru
Car: 05 CGM STi Fav Mod: grip. Location: Southeastern PA Posts: 5,828
IWSTI Addict since: Aug 2006 Trader Rating: (7) | what ive seen some pro detailers do... is apply it.. let it dry properly... then use a rotary to even it out... if its proper touch up paint itll blend perfectly |
| | #4 |
| HowTo Contributor | Yeah, i agree that if its the proper touch up from Subaru, it should match without much work |
| | #5 |
| STI Guru
IWSTI Addict since: Aug 2006 Trader Rating: (7) | |
| | #7 |
| i eat cones
Car: 08 MKV GTI Fav Mod: intake Location: ma & ri Posts: 6,923
IWSTI Addict since: Oct 2006 Trader Rating: (21) | wetsand and even it out, like said. than blend it with some polish im assuming. |
| | #8 |
| The Next Petter Solberg Car: 06 OBP STi Location: Orange County, CA Posts: 889
IWSTI Addict since: Sep 2005 Trader Rating: (9) | I'm not sure if I'd wetsand Subaru clear...only because it is so thin already... I have a pretty good chip on my left rear door...I touched it up and for about 3 days I put one light coat on it unti it was pretty even on the paint...Now I'll just have to find time to get the polisher out and use a compound to even the look out. This is my opinion of course... ![]() Kind Regards, Ryan |
| | #9 |
| STI Guru
| | #10 | |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | Quote:
Once the wetsanding is done, remove the tape. You'll see that the finish is dull and the clear coat has been scuffed. Then I use Meguiar's ScratchX as many times as needed to make it look like new. Once I'm happy with the repair, I use the Meguiar's 1, 2, 3 on it. This ad is not endorsed by this member. Please register or login to hide this ad. | |
