Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > General > Detailing & Car Care
Old 03-29-2008, 02:44 PM   #16
Default Re: Engine Detailing?
what do you guys cover in the engine bay exactly....anyone have a pic of what parts they cover and with what method?
kayno is offline   Reply With Quote
Old 03-29-2008, 03:23 PM   #17
Fav Mod: Agile protune
make sure the engine is cold, cover the alternator with a plastic bag or something similar, spray down the engine bay with water, use wheel cleaner and brush to scrub all surfaces, spray again and repeat until clean, then carefully remove plastic bag and ur done
005sti is offline   Reply With Quote
Old 03-29-2008, 03:32 PM   #18
Car: 07 Subaru WRX STi
Send a message via AIM to M.K. STI
yea my engine bay needs a detail badly!!!
M.K. STI is offline   Reply With Quote
Old 03-29-2008, 04:41 PM   #19
Car: White:05STi/04RSX-S
i ussualy do everything by hand, i use scratchX on the painted surfaces to remove thick build up. for the rest i use water and light solvent or like 005sti said "wheel cleaner" and i use rough sponge to scrub surfaces. Ive never actually sprayed downt he engine but id say as well to cover the alternator and if you have an after market intake, to cover that as well...
Es Tee Aye is offline   Reply With Quote
Old 03-29-2008, 04:51 PM   #20
Fav Mod: Greddy T-ic
Send a message via AIM to sti_nguyen
so the only things you have to cover is the alternator, battery, and aftermarket intake/sensor? Anything else i have to cover before i do some detailing on the engine bay?
sti_nguyen is offline   Reply With Quote
Old 03-30-2008, 04:10 AM   #21
yeah, just make sure the bag covering the alternator is tucked well around the alternator ad that red plug closest to the firewall. FYI my engine bay is stock and I have done mine several times without covering the battery with no problems yet, but it's probably a good idea. I also wipe down all plastic surfaces afterwards to avoid water spot formation, so the water that was sprayed on the battery, etc. was always quickly wiped off. And, when I say cold, I eliminate all guessing by detailing only after the car has been sitting all night. Lastly, the reason I spray with water is because I don't want any of the questionably flammable chemicals to burn off while I'm driving the car.
Old 04-11-2008, 12:35 PM   #22
Car: blue 04 wrx sti
is it okay to spray down your everything under the hood with water? It won't ruin anything under the hood?
sophal0303 is offline   Reply With Quote
Old 04-20-2008, 09:03 PM   #23
Car: 05 OBP WRX STi
Fav Mod: Right Foot
Its not recommended you use Simple Green unless you rinse it off very quickly (its mildly corrosive, its a mild base) but all I did was cover my K&N Typhoon cone filter (no need if you have a stock airbox), spray away with Simple Gree, give everything a good scrub with my wheel cleaning brush, and rinse away with regular hose pressure water. If you're using Simple Green, make sure to rinse EVERYTHING VERY WELL. Simple Green, if left on bare metals such as the engine block, transmission housing or intercooler can cause corrosion because it is a mild base. Just rinse it off well and you will be alright. My bottle of P21S TAW is coming in the mail
Don't worry your batter, alternator, etc are already weatherproofed. Just don't get in there with a pressure washer and it will all work out fine. the 13 volts or so provided by your car battery is not enough to break down and ionize water to conduct through it, so there is no risk whatsoever of a short or electrical damage to electrical components unless you use really really dirty salt water to wash your engine bay.
BTW does anyone use those "foamer" attachments to clean the engine bay? Like get a nice thick layer of degreaser in there, then rise it off?
atomicfire is offline   Reply With Quote
Old 04-23-2008, 07:36 AM   #24
Car: silver 04 Sti
so, its safe to get all this wet just not with pressure alot of people say to cover it with alum. foil?
axo04 is offline   Reply With Quote
Old 04-23-2008, 07:48 AM   #25
Car: Silver 07 STI
Fav Mod: Stage 1 Cobb AP
Thanks for the help! I'll be doing my engine bay today after class
that is after I go to autozone/kragen
Fletch07STI is offline   Reply With Quote
Old 05-03-2008, 10:16 PM   #26
Car: 05 OBP WRX STi
Fav Mod: Right Foot
If you want to cover it, its not going to hurt at all. When I washed my engine bay, all I covered was the Typhoon intake I have.
Old 05-04-2008, 06:13 AM   #27
LSE
Fav Mod: Defi Gauges
I'm sort of paranoid about washing the thing even if you cover some parts. My brother washed his nissan maxima's engine with just a low pressure hose one time and killed 4 sensors. Cost him like a grand to get it fixed. Normally I just clean it with a sponge in the areas where you can see.
Old 05-05-2008, 01:51 AM   #28
Car: White and Nerdy
Fav Mod: PayPal !!!
i never cover anything and the engine bay gets washed every time the exterior does .
Nasioc_STi is offline   Reply With Quote
Old 05-05-2008, 07:05 PM   #29
Car: 07 Subaru Impreza 2.
Fav Mod: Lights!(headlight, gauge, etc)
Send a message via AIM to STidriver12
wow all do some work, i just go to self carwash with powerhose
1st: turn engine off
2nd: pop the hood
3: spray the engine with the engine degrease selection(the spray should be like blue-greenish liquid to the engine)
4:let the liquid do work
5: spray it off with power water in low pressure
6: ur done with clean, close the hood
7: drive away and don't worry about smelly (it cause from engine burn the engine degrease soap)
8:enjoy see ur engine clean.
STidriver12 is offline   Reply With Quote
