| Authorized Vendor | Alright I have to say when I got the call from my customer on this one I was very excited [ ]The Porsche Carrera GT! Red on Black! 5000 miles in pretty good shape, it needed a very thorough claying, and had some swirls and light scratches that needed to be polished out, and off course the Swissvax Treatment! The interior was cleaned up and the engine was wiped down. Time: about 8 hours (2 in the crew) Take a look: Products Used: Adam's Car Wash Adam's Clay Bar with Adam's Detail Spray as lube Adam's VRT Adam's Glass Cleaner Adam's Undercarriage P21S Wheel Cleaner Gel P21S Autowash Menzerna 106 Menzerna Top Inspection Swissvax Cleaner Fluid Swissvax Concorso Einszett Leathercare Einszett ****pit Einszett Glas Polish Tools: 3m Sun Gun Metabo 12-175 with Green and Blue E2K pads Karcher pressure washer Tons of towels Procedure: Exterior: 1. Rinsed down the wheels 2. Sprayed down the wheels with some P21S Wheel Cleaner 3. Sprayed down the wheel wells and tires with P21S Autowash 3. Brush and cleaned the wheels and tires with a Boar's Hair Brush and Spoke Brush 4. Rinsed down the wheels, tires, and wheel wells 5. Rinse the car down 6. Used Adam's Car wash (the water pressure was pretty bad so we opted on not using the foam gun) 7. Rinse car off throughly with a Karcher pressure washer 8. Brought the car in and proceeded to clay the car using Swissvax Paint Rubber(yellow/ super fine) and Detail Spray removed the excess detail spray 9. Masked the car and taped off the clear bra sections. 10. Used the Metabo with Menzerna 106 to polish out all the imperfections. (blue pad) a few passes per panel at 1500 rpm (Metabo rotary) 11. After each section was corrected I buffed off the excess polish with a MF Buffing Towel. 12. Spritzed some Menzerna Top Inspection before another look with the 3m Sun Gun. 13. Applied the Swissvax Cleaner Fluid and removed with MF Buffing Towel 14. Applied the Swissvax Concorso by hand and remove with MF Buffing Towel 15. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior) 16. Polished up the glass with Einszett Glas Polish applied by hand removed by hand 17. Dressed the tires with Adam's VRT 18. Dressed wheel wells with Adam's Undercarriage Spray 19. Used Adam's Detail Spray to clean off the wheels. 20. Used the Adam's Detail Spray for a final wipe down and inspected the car. Interior: 1. Vacuumed the Interior 2. Wiped down the door jambs with Adam's Detail Spray 3. Cleaned Windows with Adam's Glass cleaner and then polished with Einszett Glas Polish 4. Interior cleaned with Einszett ****pit on the dash and everything else that was not leather 5. Cleaned and Conditioned the leather with Einszett Leather care Engine: 1. Wiped down the dust with a MF towel misted with Adam's Quick Detail Spray 2. Rubber and plastics treated with Adam's In and Out Spray Interior Before: ![]() ![]() ![]() ![]() Me brushing away: ![]() Interior After: ![]() ![]() ![]() ![]() ![]() Engine: ![]() Before shots: ![]() ![]() ![]() ![]() ![]() Dirty wheels (ceramic brakes create very little brake dust) ![]() ![]() This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Authorized Vendor | P21S wheel cleaner gel in action: ![]() ![]() ![]() ![]() Vacuuming out the vents (lots of loose road debris in there) ![]() Washing: First shot little to no pressue ![]() Washing the car down: ![]() ![]() Final rinse: ![]() Swissvax Paint rubber (claying): ![]() Dan from Concierge Motors attention to detail ![]() Masking away: ![]() ![]() Imperfections it hard to tell but its there: ![]() ![]() After Polish: ![]() ![]() ![]() ![]() |
| | #5 |
| aka: jnprn2003
Car: 07 STi, 07 Speed 3.. Fav Mod: EFI Logics tunage Location: The Ocean State Posts: 2,879
IWSTI Addict since: Feb 2007 Trader Rating: (13) | Wow...nice job. Too bad you are so far away. |
| | #7 |
| Junior STI Driver Car: Aw 06 Sti Stg 2 Fav Mod: Cobb stg2 tuned by MSPT Location: Jerzey Posts: 151
IWSTI Addict since: Sep 2006 Trader Rating: (0) | WHere in Jersey are you located? After seeing those pics I think I will be treating my car to some of your treatment. How much would a top quality job like that set me back? PM me if you want. |
| | #9 |
| STI Driver
Car: 2k4 Psm stage 2 Sti Fav Mod: Hks Hi-power Location: Boston Posts: 287
IWSTI Addict since: Jan 2006 Trader Rating: (0) | i need to buy some of these products for my car. As always very nice work. |
| | #12 |
| Authorized Vendor | yes its an amazing car and the sound is quite amazing! This ad is not endorsed by this member. Please register or login to hide this ad. |
