Old 11-16-2007, 07:48 PM   #1
IWSTI Addict since: Jul 2007
Default Detailer's Domain and the Porsche Carrera GT
Alright I have to say when I got the call from my customer on this one I was very excited []
The Porsche Carrera GT! Red on Black! 5000 miles in pretty good shape, it needed a very thorough claying, and had some swirls and light scratches that needed to be polished out, and off course the Swissvax Treatment! The interior was cleaned up and the engine was wiped down.
Time: about 8 hours (2 in the crew)
Take a look:
Products Used:
Adam's Car Wash
Adam's Clay Bar with Adam's Detail Spray as lube
Adam's VRT
Adam's Glass Cleaner
Adam's Undercarriage
P21S Wheel Cleaner Gel
P21S Autowash
Menzerna 106
Menzerna Top Inspection
Swissvax Cleaner Fluid
Swissvax Concorso
Einszett Leathercare
Einszett ****pit
Einszett Glas Polish
Tools:
3m Sun Gun
Metabo 12-175 with Green and Blue E2K pads
Karcher pressure washer
Tons of towels
Procedure:
Exterior:
1. Rinsed down the wheels
2. Sprayed down the wheels with some P21S Wheel Cleaner
3. Sprayed down the wheel wells and tires with P21S Autowash
3. Brush and cleaned the wheels and tires with a Boar's Hair Brush and Spoke Brush
4. Rinsed down the wheels, tires, and wheel wells
5. Rinse the car down
6. Used Adam's Car wash (the water pressure was pretty bad so we opted on not using the foam gun)
7. Rinse car off throughly with a Karcher pressure washer
8. Brought the car in and proceeded to clay the car using Swissvax Paint Rubber(yellow/ super fine) and Detail Spray removed the excess detail spray
9. Masked the car and taped off the clear bra sections.
10. Used the Metabo with Menzerna 106 to polish out all the imperfections. (blue pad) a few passes per panel at 1500 rpm (Metabo rotary)
11. After each section was corrected I buffed off the excess polish with a MF Buffing Towel.
12. Spritzed some Menzerna Top Inspection before another look with the 3m Sun Gun.
13. Applied the Swissvax Cleaner Fluid and removed with MF Buffing Towel
14. Applied the Swissvax Concorso by hand and remove with MF Buffing Towel
15. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior)
16. Polished up the glass with Einszett Glas Polish applied by hand removed by hand
17. Dressed the tires with Adam's VRT
18. Dressed wheel wells with Adam's Undercarriage Spray
19. Used Adam's Detail Spray to clean off the wheels.
20. Used the Adam's Detail Spray for a final wipe down and inspected the car.
Interior:
1. Vacuumed the Interior
2. Wiped down the door jambs with Adam's Detail Spray
3. Cleaned Windows with Adam's Glass cleaner and then polished with Einszett Glas Polish
4. Interior cleaned with Einszett ****pit on the dash and everything else that was not leather
5. Cleaned and Conditioned the leather with Einszett Leather care
Engine:
1. Wiped down the dust with a MF towel misted with Adam's Quick Detail Spray
2. Rubber and plastics treated with Adam's In and Out Spray
Interior Before:
Me brushing away:
Interior After:
Engine:
Before shots:
Dirty wheels (ceramic brakes create very little brake dust)
Old 11-16-2007, 07:50 PM   #2
Default Re: Detailer's Domain and the Porsche Carrera GT
P21S wheel cleaner gel in action:
Vacuuming out the vents (lots of loose road debris in there)
Washing:
First shot little to no pressue
Washing the car down:
Final rinse:
Swissvax Paint rubber (claying):
Dan from Concierge Motors attention to detail
Masking away:
Imperfections it hard to tell but its there:
Old 11-16-2007, 07:51 PM   #3
After Polish:
After Swissvax Cleaner Fluid:
Concorso:
Concorso applied:
Dan removing the Concorso:
Old 11-16-2007, 07:52 PM   #4
Tons of Afters:
Old 11-16-2007, 07:52 PM   #5
Last shot:
Old 11-16-2007, 07:57 PM   #6
Car: 06 WRB/Gold STI
Fav Mod: Clutch Judder
IWSTI Addict since: Aug 2006
Send a message via MSN to YeloFva
Wow! After 8 hours of cleaning, I wouldn't even want to drive the car
If you don't mind me asking, how much do you guys charge?
YeloFva is offline   Reply With Quote
Old 11-16-2007, 07:59 PM   #7
depends on the car and what the customer wants done.
$350 up to $$$$.00
