Old 08-22-2007, 10:43 AM   #1
Default Cannot Save Base Map
Can someone please help me with this?
Why does ST keep giving me an "over capacity by xxx bytes" error message when trying to save a base map?
I had only altered 3 cells in the Throttle Duty Cycle map and ST keeps telling me that I am "over capacity by xxx bytes" and will not allow me to save a basemap that my tuner gave me to play with.
Kinda off topic here... but I searched high and low and even in Cobb's own forums, and no answers... the last post on the same issue in Cobb's forum was dated Apr-2007 and no one from Cobb bothered to answer. Is it just me or does it seem like Cobb does not have good tech support/after sales service?
singlefin is offline   Reply With Quote
Old 08-22-2007, 11:36 AM   #2
Default Re: Cannot Save Base Map
too much data in the file. when that happens i usually make the file name shorter and it is enough to save the file. give it a shot.
Spunky424 is offline   Reply With Quote
Old 08-22-2007, 04:11 PM   #3
Start with a stock base map and only make the changes you HAVE too in the base map. Then move all other changes to a real time map. It sucks too have a non safe base map but that is what the 04 guys are stuck doing.
TheMadScientist is offline   Reply With Quote
Old 08-24-2007, 11:22 AM   #4
Car: 05 WRX STi
^ or untill the version 2 StreetTUNER comes out.
